(-5) Error Code thread for the intune
RE: error pics
Tried it. Didn't work for me. Fortunately I saved the file to my computer so I can put it back on now.
RE: error pics
Just got off the phone with Jon from Diablo. We worked on it for about an hour and finally got my car to calibrate and load a tune. We're good to go. I'm sure they will have everything figured out for the others real soon.
Jon - Thanks man!
Jon - Thanks man!
- JonDiablosport
RE: error pics
yes we do have a possible tempory fix. it requires a call to us. Since I have been the one to work this situation out with our engineer You may contact me if youd like.
also you can delete that DRG file on your intune directory. then unplug then plug back in and allow it to check to see if it needs another update. if it does not autodownload a new DRG file to your system. then call us up shoot me an email at [email protected] with your INFO.xml file attached.
also please post up possitive or negative. This may not work for all but right now it has worked. I would like to confirm it again so if someone with some time please call me on the tech line and I will go through the process with you as well.
Re: RE: Re: RE: (-5) Error Code thread for the intune
Mine is 050302232ADJonDiablosport wrote:
Can some of you post your calibration numbers.
to get cal numbers goto settings-tool info- vehicle info-cal id, generally you have to be in the vehicle to get this info.
The serial number is CIA9YE2-1
Made 12/5/11 7:45:46
I removed the file. Nothing changed. I can't delete the vehicle info because I need a code. I can't get a code because I can't register. Any other way to restore the settings to factory fresh?
- JonDiablosport
RE: Re: RE: Re: RE: (-5) Error Code thread for the intune
the code is different that what you need to register.
the code can only be received by us. over the phone. Feel free to contact me and we can attempt to get you up and running.
i will b contacting u tomorrow when u guys r open to see if it will work for me.
and heres my intune info
<?xml version="1.0"?>
-<tool_info> <main svn="3652" sw_rev="1r01c" full_version="InTune-1r01c 12/05/2011 07:45:46 AM"/> <registration status="0" sn="CIAJPBE-1"/> <restore bc="0" vin="1J8HR78397C657297" id="0"/> <db pid="1r01a" tune="1r01a" mfr="GM"/> <db pid="1r01a" tune="1r01a" mfr="DCX"/> <db mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> </tool_info>
calid: 05030307AE
I just got back from my test drive with my new tune on my car. That's right Jon fixed me up after a marathon phone call. The good news for the rest of you is he used my intune as a guinea pig so hopefully he will be able to fix you up quicker.
The problem (as I understand it) is the communication between the downloaded file and the intune. We repeated the same steps numerous times before on the very last try before giving up it worked. The issue is like have a car that has a problem but only intermittently so that when you take it to the mechanic of course he hears nothing.
I can also confirm that the registration error and this problem have no relation as I am still not able to register my itune. The registration does prohibit a self fix though because you have to call to get the code to reset the unit to factory fresh so they can get the right file on the itune.
Anyway Jon asked me to post up and tell you I'm fixed and you should give them a call to fix the problem. Before you call I'd take a laptop with an internet connection, your phone, the intune and all appropriate cables to your car as you will probably be bouncing back and forth between car and computer multiple times.
Oh yeah and the tune is awesome so far. I haven't much time to play but the car definitely feels much better to drive.
good!grayfz1 wrote:I just got back from my test drive with my new tune on my car. That's right Jon fixed me up after a marathon phone call. The good news for the rest of you is he used my intune as a guinea pig so hopefully he will be able to fix you up quicker.
It worked for me guys on the first try. thank you jon for your help and your time.
- JonDiablosport
give me a call because your info.xml does not show cal needed we have to clear the tool and go from there.bert6samson9 wrote:john its brett shot you an email hope you got it erased erg file tried update and nothing so ill call you in the morning and i hope it doesnt take to long dont imagine its cheap calling from canada
we have helped a total of 5+ people so far get past this issue.
