2004 Dodge Ram 5.7 Hemi
hd02deuce
05 5.7 hemi problem
Post by hd02deuce »
05 dodge ram 1500 2wd, slt daytona model, 5.7 hemi
hd02deuce
Post by hd02deuce »
same problem, got new update today when plugged in and tried it, for the first time I got a new screen that said "pcm tune for my vin currently not available, connect to another pc to see if cal is available", now what?
hd02deuce
Post by hd02deuce »
connected and tried to update but it said currently no update available.
Nolimitzr1
Post by Nolimitzr1 »
Mine did it after update...went to dealer...flashed pcm...worked after that. Havent seen calid database updated yet. From updater
hd02deuce wrote:connected and tried to update but it said currently no update available.
did the tool ask you to do a calibration update?
can you please go to the intune drive and copy the info.xml file and email it to us or post it here?
hd02deuce
Post by hd02deuce »
yes it asked for a calibration update, but when I plugged in and tried for an update it said I was up to date with the most current cals and no update available, sent you an email, couldnt get file to paste to this
Nolimitzr1
For what its worth after I updated intune but before dealer flashed my pcm. I had calibration unsupported and told me to plug into pc. I did and did nothing for me, now i had dealer flash my pcm and worked fine. Just shedding a little more light on the issue for diablo to figure it out.
hd02deuce
Post by hd02deuce »
You took it to your dodge dealer for a flash, or a diablo dealer? And if a dodge dealer what reason did you use to have them flash your pcm ? Thanks
Nolimitzr1
Dodge dealer, just told the to flash latest revision, as I knew I was one below the most current.
xtreme
Post by xtreme »
Ok, new updates to issues with this truck.
Installed the latest update to the truck, downloaded the stock tune.
Opened the stock tune in CMR, edited the file and saved. Would not let me save as a different name, had to change the name after it was saved.
Loaded the new file on the intune, and plugged into the truck. Now I get connect vehicle message, willl not flash the truck. Disconnected and reconnected the intune multiple times, no luck.
Key on or off get the same message, like the intune can't tell if it is connected or not.
Really fustrated with it at this point, and still can't tune this truck.
Thought I was in the home stretch with this.
HELP!!!
did it import the custom tune?
try deleting the custom tune and see if that changes anything?
