InTune Gear Ratio Changes?
Re: InTune Gear Ratio Changes?
please post the tunes from the intune drive/tunes folder.
jstuart83
Post by jstuart83 »
Im just curious I ordered one of the I2 from you guys today. I have a 05 GMC Serria with 35 inch tires and am having it re geared to 4.88's. Has this issue been resolved with a SW update? Looking through multiple forums I found many posts about the the gear ratio not being selectable or the options jumping from 4.56 to like 5.13. most of these were older posts this is the most current one i have came across. Also I have an adapter on the factory Bose stereo that allows me to interface with a AUX and iPod should i remove it before trying to flash. Looking at this thread I found the stereo adapter issue interesting since i also have something like that.
some cals do not have the options, so we need to do it in a custom tune.
If you see the axle ratio option there it will work.
stk-snd
Post by stk-snd »
I have sane issues how do I adjust in a 2005 Silverado 3.42 to 4.10....I called does said no problem...I am confused.
post the file from the tunes folder here and tell me what the stock and new gear ratios were.
LST3
Post by LST3 »
My stock axle ratio was 3.42, and I changed them to a 4.10 ratio. Here are the files from my intune, can you update the tune for me?
PCM_12607058_LastTuneWritten.grg
(33.71 KiB) Downloaded 393 times
PCM_12607058_Backup.grg
(34.13 KiB) Downloaded 370 times
Zach
Post by Zach »
LST3 wrote:My stock axle ratio was 3.42, and I changed them to a 4.10 ratio. Here are the files from my intune, can you update the tune for me?
Updated tune attached.
PCM_12607058_410s.grg
(31.44 KiB) Downloaded 435 times
LST3
Post by LST3 »
Awesome thank you
redbeerde
Post by redbeerde »
Bringing this dead thread back to life.
Running into the same issue. Regeared from 3.73 to 4.56. My InTune does not give me the option to adjust gear ratio. Looking to get a tune with updated gear ratio baked into it.
Side note, will I be able to adjust other parameters (tire size, shift points, etc..) while maintaining the gear ratio change?
PCM_09357624_LastTuneWritten.grg
(26.13 KiB) Downloaded 332 times
PCM_09357624_Backup.grg
(26.08 KiB) Downloaded 353 times
Zach
Post by Zach »
redbeerde wrote:Bringing this dead thread back to life.
Load this tune up and the speedo will be dialed in for the gears.
you'll still be able to make all other user adjustable changes.
PCM_09357624_456s.grg
(24.08 KiB) Downloaded 333 times
Brandon_pros96
Post by Brandon_pros96 »
I'm having the same problem I went from a 3.73 to 4.88. also I'm not able to turn tq management off. could you do that also?
PCM_09357593_LastTuneWritten.grg
(26.08 KiB) Downloaded 305 times
PCM_09357593_Backup.grg
(26.11 KiB) Downloaded 356 times
