11-12 Charger, 300, Challenger, 3.6 needed for testing :)
TheyCallMeMike
Re: 11-12 Charger, 300, Challenger, 3.6 needed for testing :
Do you think we can do this by Monday?! I will be able to have it there by 8:30-9:00 am
- smackdownsrt
2013superbee wrote:What about the 2013 srt cars? I have an intune I1000 DCX sitting here since january.Is the 3.6 tune the same for the 13 SRT's? If you need my 13 Superbee SRT Charger I can bring it in.
Regards,
Raul Valdez
...to be supported by Diablosport...
TheyCallMeMike
Or I could drop it off Friday morning and let you have it the weekend!
could you leave it until tuesday morning?TheyCallMeMike wrote:Or I could drop it off Friday morning and let you have it the weekend!
TheyCallMeMike
Yep, as long as Id have the loaner, you can keep it til its done!
perfect, lets do itTheyCallMeMike wrote:Yep, as long as Id have the loaner, you can keep it til its done!
TheyCallMeMike
Alright, Ill have it there Friday morning around 8:30-9:00am!
perfect, see you then.
rapture333
Hey Mike, I have a 2012 3.6l Dodge Charger SE with a 5 speed. Do you still need tester cars? I'd be willing to drop mine off at any time, I'm in Miami and am very close! As long as I have something to drive back you can use it for as long as you need.
Got your email, thanksrapture333 wrote:Hey Mike, I have a 2012 3.6l Dodge Charger SE with a 5 speed. Do you still need tester cars? I'd be willing to drop mine off at any time, I'm in Miami and am very close! As long as I have something to drive back you can use it for as long as you need.
Little update...
The Chally picked up nicely, solid 10 rwhp and 15 ft/lbs across the board, and it felt a TON better on the street, despite the minimal power gains
So is that the rear wheel gain on a stock application? Which octane rating was that with? Thats pretty decent, add CAI, exhaust, cooler thermostat (for heat soak), tcm control (when made available) and a set of gears and it really starts to add up quickly.mikel wrote:Little update...
mbasobas95
Will the tuner take out the throttle lag? Sorry this is my first time buying a tunermikel wrote:Little update...
There is a feature called throttle booster and it can be changed by % it is intended and advertised to eliminate the drive by wire throttle lag and dial up throttle sensitivity.mbasobas95 wrote:Will the tuner take out the throttle lag? Sorry this is my first time buying a tunermikel wrote:Little update...
TheyCallMeMike
Ended up getting here a lot earlier than expected
