Page 3 of 6
Re: 11-12 Charger, 300, Challenger, 3.6 needed for testing :
Posted: Tue Apr 16, 2013 12:20 pm
by TheyCallMeMike
Do you think we can do this by Monday?! I will be able to have it there by 8:30-9:00 am
Posted: Tue Apr 16, 2013 1:02 pm
by smackdownsrt
2013superbee wrote:What about the 2013 srt cars? I have an intune I1000 DCX sitting here since january.Is the 3.6 tune the same for the 13 SRT's? If you need my 13 Superbee SRT Charger I can bring it in.
Regards,
Raul Valdez
Posted: Tue Apr 16, 2013 9:33 pm
by TheyCallMeMike
Or I could drop it off Friday morning and let you have it the weekend!
Posted: Wed Apr 17, 2013 4:38 pm
TheyCallMeMike wrote:Or I could drop it off Friday morning and let you have it the weekend!
could you leave it until tuesday morning?
Posted: Wed Apr 17, 2013 4:47 pm
by TheyCallMeMike
Yep, as long as Id have the loaner, you can keep it til its done!
Posted: Wed Apr 17, 2013 4:55 pm
TheyCallMeMike wrote:Yep, as long as Id have the loaner, you can keep it til its done!
perfect, lets do it :)
Posted: Wed Apr 17, 2013 4:58 pm
by TheyCallMeMike
Alright, Ill have it there Friday morning around 8:30-9:00am!
Posted: Wed Apr 17, 2013 4:59 pm
perfect, see you then.
Posted: Wed Apr 17, 2013 5:34 pm
by rapture333
Hey Mike, I have a 2012 3.6l Dodge Charger SE with a 5 speed. Do you still need tester cars? I'd be willing to drop mine off at any time, I'm in Miami and am very close! As long as I have something to drive back you can use it for as long as you need.
Posted: Thu Apr 18, 2013 5:38 pm
rapture333 wrote:Hey Mike, I have a 2012 3.6l Dodge Charger SE with a 5 speed. Do you still need tester cars? I'd be willing to drop mine off at any time, I'm in Miami and am very close! As long as I have something to drive back you can use it for as long as you need.
Got your email, thanks :)
Posted: Thu Apr 18, 2013 5:39 pm
Little update...
The Chally picked up nicely, solid 10 rwhp and 15 ft/lbs across the board, and it felt a TON better on the street, despite the minimal power gains :)
Posted: Thu Apr 18, 2013 6:24 pm
by cq842000
mikel wrote:Little update...
So is that the rear wheel gain on a stock application? Which octane rating was that with? Thats pretty decent, add CAI, exhaust, cooler thermostat (for heat soak), tcm control (when made available) and a set of gears and it really starts to add up quickly.
Posted: Thu Apr 18, 2013 7:10 pm
by mbasobas95
Will the tuner take out the throttle lag? Sorry this is my first time buying a tuner
Posted: Thu Apr 18, 2013 7:56 pm
by cq842000
There is a feature called throttle booster and it can be changed by % it is intended and advertised to eliminate the drive by wire throttle lag and dial up throttle sensitivity.
Posted: Fri Apr 19, 2013 7:39 am
by TheyCallMeMike
Ended up getting here a lot earlier than expected :D
