orginal backup its better than tuned
joker99911
Re: orginal backup its better than tuned
Post by joker99911 »
No one. Active
joker99911
where r you mike ?????
He's in Las Vegas at the SEMA show.
joker99911
What's is your suggesion at my car
sharkcohen
Post by sharkcohen »
Run the 93 tune with your 98 octane, add 5% fuel across the rpm range, log again and see if you get knock. If you get knock, try adding a little more fuel, or try the 91 octane tune with 5% fuel. Keep logging, see if you can get rid of the knock with added fuel. If you can't, try a different brand of fuel.
joker99911
what your suggest mikel???
sharkcohen
He will suggest the exact same thing.
joker99911
sharkcohen wrote:He will suggest the exact same thing.
i make what you told me and it come more wors
ABCD.LOG
(156.69 KiB) Downloaded 212 times
joker99911
week support here
:drivingbad:
iRace559
Post by iRace559 »
I've run every single brand of 93 octane in town, on the 91 map with +10% fuel across the board and I still get knock. I've pretty much just given up at this point. 600 paperweight.
garrett
Site Admin
Post by garrett »
iRace559 wrote:I've run every single brand of 93 octane in town, on the 91 map with +10% fuel across the board and I still get knock. I've pretty much just given up at this point. 600 paperweight.
Why not use the tune designed for 93 octane then
joker99911
i trying but thers no chance aslo getting knock
Thats because the Hemi is poorly designed. The combustion chambers don't dissipate heat properly, the fuel isn't injected in the right place, and the compression is too high for the way its set up. Thats why it knocks stock, and by adding advance, it makes the knock even worse.
The whole top end of the Hemi needs to be redesigned. They need to either use real hemispherical chambers, or go back to pent roof. The hybrid isn't working. They cause hotspots. And they need to inject the fuel directly into the chambers, at higher pressure and a finer spray. Then the knock issues will no longer exist. Will Chrysler do it? Doubt it. They refuse to admit when they're wrong, so they'll keep pushing this crummy design.
joker99911
so what i have to do and why my freind car its come good with the tune
iRace559
Post by iRace559 »
I don't see how that could in any way reduce knock.\
