Page 3 of 4
Re: orginal backup its better than tuned
Posted: Fri Nov 08, 2013 12:10 pm
by joker99911
No one. Active
Posted: Fri Nov 08, 2013 2:00 pm
by joker99911
where r you mike ?????
Posted: Fri Nov 08, 2013 5:20 pm
by Mike_Levy
He's in Las Vegas at the SEMA show.
Posted: Fri Nov 08, 2013 6:37 pm
by joker99911
What's is your suggesion at my car
Posted: Fri Nov 08, 2013 8:29 pm
by sharkcohen
Run the 93 tune with your 98 octane, add 5% fuel across the rpm range, log again and see if you get knock. If you get knock, try adding a little more fuel, or try the 91 octane tune with 5% fuel. Keep logging, see if you can get rid of the knock with added fuel. If you can't, try a different brand of fuel.
Posted: Sat Nov 09, 2013 3:25 pm
by joker99911
what your suggest mikel???
Posted: Sat Nov 09, 2013 5:46 pm
by sharkcohen
He will suggest the exact same thing.
Posted: Sat Nov 09, 2013 6:18 pm
by joker99911
sharkcohen wrote:He will suggest the exact same thing.
i make what you told me and it come more wors
Posted: Sun Nov 10, 2013 11:41 am
by joker99911
week support here
:drivingbad:
Posted: Sun Nov 10, 2013 12:29 pm
by iRace559
I've run every single brand of 93 octane in town, on the 91 map with +10% fuel across the board and I still get knock. I've pretty much just given up at this point. 600 paperweight.
Posted: Sun Nov 10, 2013 1:20 pm
by garrett
iRace559 wrote:I've run every single brand of 93 octane in town, on the 91 map with +10% fuel across the board and I still get knock. I've pretty much just given up at this point. 600 paperweight.
Why not use the tune designed for 93 octane then
Posted: Sun Nov 10, 2013 3:33 pm
by joker99911
i trying but thers no chance aslo getting knock
Posted: Sun Nov 10, 2013 7:14 pm
by Mike_Levy
Thats because the Hemi is poorly designed. The combustion chambers don't dissipate heat properly, the fuel isn't injected in the right place, and the compression is too high for the way its set up. Thats why it knocks stock, and by adding advance, it makes the knock even worse.
The whole top end of the Hemi needs to be redesigned. They need to either use real hemispherical chambers, or go back to pent roof. The hybrid isn't working. They cause hotspots. And they need to inject the fuel directly into the chambers, at higher pressure and a finer spray. Then the knock issues will no longer exist. Will Chrysler do it? Doubt it. They refuse to admit when they're wrong, so they'll keep pushing this crummy design.
Posted: Sun Nov 10, 2013 7:27 pm
by joker99911
so what i have to do and why my freind car its come good with the tune
Posted: Sun Nov 10, 2013 9:07 pm
by iRace559
I don't see how that could in any way reduce knock.\
