ALREADY REPLACED ECM N NOW ITS DONE IT AGAIN!! DEAD N WATER!
junior38320
Re: ALREADY REPLACED ECM N NOW ITS DONE IT AGAIN!! DEAD N WA
Post by junior38320 »
hey mike it made it in today about mid day so thats awesome for starters. no here is were it gets questionable, the paper says everything was good n all. so i went out and installed the ecm back on my truck, hooked the batteries up, and turned the key and bam....same thing .... nothing. just like it was before i sent it to ya. do i need to hook up my predator and reinstall the original back up or something? or is there something else goin on? also, when should i be expect the charges to be billed to me? havent seen anything about that either since when i filled out the form .... :|
well, are you 100% sure everything is fully plugged in/connected properly?
When you try to start it, is there a theft/security indicator on the dash flashing or lit up solid?
junior38320
its posting up service brake system on the dash mike. as far as i know everything has good connections. im on phone now call yall waiting for someone to answer hopefully...
junior38320
i got it mike !!! i went back out and looked over every lil thing .... i ended up pulling ecm fuse and forgot to re-install it. put it in and it fired right up!!!!! man i cant thank yall enough !!! specially u dude lol thanks for taking care of all this. customer service is awesome .... but i would like to know about the billing when u get chance . thanks again !!!!! :lol:
whew...you were bugging me out man!
I was running around making sure they tested the PCM, they were telling me 'no way, it was fine'...glad it worked out :)
no charge, this shouldn't have happened.
junior38320
Man thanks again Mike and the rest of yall for doing a great job of helping this guy out !!! when i decide to upgrade ill def keep diablosports in mind. i def give customer service a 10 in my book, even if ya do have to wait a while on phone sometimes lol none the less thanks !!! 8)
