2014 Mustang 5.0
armyguy202000
Re: 2014 Mustang 5.0
Post by armyguy202000 »
ok fyi I my air fuel is not even dropping below 20.0 until 3500 rpm then only to about 19.3 ill post what you ask for in a bit
armyguy202000
no still the same JLT boss was only addition
armyguy202000
Ok so here is the previous tune which I was running before the Boss intake. I ran the data log until the car died.
1ZVBP8CF6E5281117_03.log
Log for this tune
(226.13 KiB) Downloaded 163 times
PCM_FPFD32A_LastTuneWritten.frg
Last Tune
(593.31 KiB) Downloaded 149 times
DiabloMatt
Post by DiabloMatt »
man I can fix this but are you SURE there is no vacuum leaks? the fuel trims are ADDING 65%!!!! like I said. I can fix but just want to make sure before proceeding
armyguy202000
ill double check but only had to disconnect one
armyguy202000
I checked I don't have any different sucking sounds but kind of hard to tell with the JLT CAI and throttle body spacer. So I took off a line and blew smoke (lots) and nothing so unless its leaking from the head (I couldn't feel anything and no check engine lite is on) IDK.
DiabloMatt
here go... this is 65 across the board... shooting in the dark at this point but we will conquer !!! lol
if it will idle and warm up try some part throttle driving and if its ok get me like a 3rd gear WOT...
pcm_fpfd32a_r2d.frg
(550.05 KiB) Downloaded 160 times
armyguy202000
ok part throttle driving?
armyguy202000
IDK man so this seems to be a bit better but the idle will not go down once I press on the gas. and I have a check engine lite now. I am going to get a bottle of carb cleaner and hit around where the manifold and block meet.
1ZVBP8CF6E5281117_04.log
(124.68 KiB) Downloaded 151 times
DiabloMatt
if it seems like its ok, yes.
basically need a log covering all driving conditions so I can ajust areas other than just idle
DiabloMatt
please do....I has to be getting air from somewhere. the throttle blade is closing down to 4% but the idle is hanging way high. something is not right... :(
armyguy202000
Matt-
So after switching the gaskets off the stock manifold I still had the same leak in the same spot. I took the boss intake back off and took the fuel rail off and one of the O-rings from the fuel injectors had come off. Got new O-rings put it back on and no leak. I am running the first tune you sent me (r2c.frg) and it is doing good. The only issue I am having is if I come to a sudden stop to where the RPM's drop fast it will die. If you could provide the adjustment to account for this I think ill be in business. Thanks :!:
DiabloMatt
good to hear :)
get me an idle log, driving around and possibly a WOT and sent it to me. i'll finish it up :)
armyguy202000
Matt-
Sorry it took so long I haven't been home for awhile. Here is the log I took yesterday from idle through 3rd at WOT. Again the major issue is the car will die when it is cold or if I come to a quick stop and the RPM drop to fast. Thanks
1ZVBP8CF6E5281117_05.log
(203.02 KiB) Downloaded 129 times
DiabloMatt
ill get you some adjustments.... you DO have 93 octane in this right? im asking as the knock sensors seemed pissed pulling some timing.
edit.... forgot this was 91
