Updates
Re: Updates
Yes i got that one but if you load the 87 tune with either the rev limiter removed or speed limiter removed the vehicle will not accelerate in drive at all.
Re: Updates
dont disable speed limit through easy tune, there is a bug, if you want it disabled, use advanced tune and it will work fine.
Re: Updates
Hello, I got my i2 yesterday in and i connected to my car and after and when i hit tune it always says " the vehicle is not supported it may not and may need an update by a PC." So i connected it to the computer and i updated it and after that i went back to my car and it keeps saying the same thing. I really want it to work because it wasn't cheap.
Hemilicious
Re: Updates
HI I have a 2013 dodge ram 1500 hemi I am having the same problem I can't get my mds to turn off did you ever have any luck with yours. Thanks Kevinnewcombpatrick wrote:I loaded the 93 octane tune without adjusting the speed limiter and it loaded fine. The truck is running fine now. The issue that I have now is I can't turn my MDS off. I'm running a custom tune from HEMIFEVER and when I attempt to turn my MDS off after I apply the tune, I go back and the tuner is showing that MDS is still on. Any ideas. It did the same thing when I tried it with the stock 93 octane tune. Thanks.
Re: Updates
The requested resource cannot be found on this server.[/quote]Hemilicious wrote:HI I have a 2013 dodge ram 1500 hemi I am having the same problem I can't get my mds to turn off did you ever have any luck with yours. Thanks Kevinnewcombpatrick wrote:I loaded the 93 octane tune without adjusting the speed limiter and it loaded fine. The truck is running fine now. The issue that I have now is I can't turn my MDS off. I'm running a custom tune from HEMIFEVER and when I attempt to turn my MDS off after I apply the tune, I go back and the tuner is showing that MDS is still on. Any ideas. It did the same thing when I tried it with the stock 93 octane tune. Thanks.
Please send me a copy of the info file. To retrieve it, plug the tool into your computer, and browse for the I2 drive that will show under "Computer" or "This PC" (Desktop if it's a Mac). Make a copy of the ‘info.xml’ file in that drive by dragging and dropping it to your desktop and email it to me as an attachment.
Re: Updates
can someone tell me is it possible to get my stock 2010 challenger RT 5.7 to make 600rwhp with just bolt on parts with out using a turbo or supercharger???? i an including a cam also. any suggestions on whitch parts and how to modify them
Re: Updates
I have an 2011 F150 Ecoboost and I am getting the same message.... Where do we get the update..????????Dequionta wrote:Hello, I got my i2 yesterday in and i connected to my car and after and when i hit tune it always says " the vehicle is not supported it may not and may need an update by a PC." So i connected it to the computer and i updated it and after that i went back to my car and it keeps saying the same thing. I really want it to work because it wasn't cheap.
Re: Updates
Please post your info file (fond in the i2 drive of your computer) here or email it to me directly, and I can look into it.mvtharley wrote:I have an 2011 F150 Ecoboost and I am getting the same message.... Where do we get the update..????????Dequionta wrote:Hello, I got my i2 yesterday in and i connected to my car and after and when i hit tune it always says " the vehicle is not supported it may not and may need an update by a PC." So i connected it to the computer and i updated it and after that i went back to my car and it keeps saying the same thing. I really want it to work because it wasn't cheap.
Re: Updates
Did you locate the i2 drive, and then the Tunes folder inside it? To copy the files to your Desktop, just drag and drop them or right-click and copy then right-click and past it to the Desktop or into a folder.cmolnaird wrote:For some reason i can't export my backup file or the tune from the tuner.
Re: Updates
got my i2 today and trying to do the update on my mac and keeps saying cannot locate the info xlm.file any help would help thanks
Re: Updates
I have recently bought a 2011 JK which had your Diablo i2 tuner. The previous owner had not used the Tuner for some time as he had had a Supercharger install and removed it before selling the car to me. I am now trying to reinstall the Diablo tune but each time I try and connect to the computer it states it's up to date but when I plug it into the car it ask for an update and I have 2 x choices of a, tick or a , cross. Either options wants me to unplug and update but I can't get any further. If I go back to the computer it just states it up to date.
How can I check ALL updates are applied. Also what tunes should show in the TUNES Folder. See attached the 2 x screen shots of these folders. I have also noted a file named "updateOFF.upd " Does this mean my updates are turned off?
I hope you can help?
Here is a copy of my info file:
<?xml version="1.0"?>
-<tool_info>
<main svn="8521" sw_rev="1r04i" full_version="InTune-1r04i 08/03/2015 01:32:36 PM"/>
<registration status="1" sn="CIC2467-1"/>
<cal_id PCM="68057143AE"/>
<restore bc="21" vin="1J4HE6H15BLXXXXXX" id="0"/> (I have removed my VIN info for privacy)
<system_db vin="1r01a" dtc="1r01a" info="1r01b"/>
<db pid="1r01a" tune="1r01b" mfr="DCX"/>
<db pid="1r01a" tune="missing" mfr="FORD"/>
<db pid="1r01a" tune="1r01k" mfr="GM"/>
-<license tuned="1" avail="1">
<tuned vin="1J4HE6H15BL564453"/>
</license>
<updates count="7"/>
<oem tool_oem="DIABLO"/>
<reg reg="ThHG+Qvmti4ohnLlxsBo152U7Thrvmc/zWgHK6dJGdbAjcxIqwVezhxJnKt5fTuavSJODY3g2QNfkeJWbBkktXuF48QW3EM7ERAtoPFCZHMV2WWztLs+/jDxVORHVZuD5Uk3VSgfbb8jk76yfcolF8ONsOIyfdvm81GloMd9tZawqiaSy/8qY+BK/+9FNrFThYuc9mNAxOm4wpIWttjtCaD2mb20qErPUghcDLPz4jXsrj6KTF/M2Vy6y4wE5CiZ83dLAT0Is+mneuPCFv+WbzOlnZMexX26YLbyPPTyJgBaaoZa64l1yLbEUtiJodq7SEkRhrufPacGza2ji09VG0c3kJfQXa1jqLqvhH5S00APRzRPgOuBhqVnz/inglTok7VTwWMalaogaeOhcI74vYFLw2npeJ6e/EL4nlLDc5kJLry6Qypo0nV11Oy1ro5M8DUattSqiTIgYyi1t2NEtRX28oFunftdID49WP5/UHHumgy5UEGRmQuysf8YihhWvSaB4di/8QFdpr63iFHXHg1tNDubz5pMccHz8dkhtdCqsHNJD3yt5jY1ZZ9I+errKhp90u/ru4LO2i67qeNQsSAltyVZOUlMj5UWncJ+vno4Y+nV8Lt7kTHrsMYnYLk4rvTsPUka1qiSDv7H6VL8VzRB7NZF52zoI4fI5oDLrPUj/yv6ClqQlhcq1U7dRFY3eKcXBkPtJYDBqafJyKoAAnuz1rhs+oLsrwzeK9ZVzR9bMEg57qT9SB73AwnooCK8TUczvlGNXffANVzDIownoPdWVkieYZKql+mumXWmwxXlxKIHDa6T/XbKQMoJom1Vgz864s+cy6bp/lteN/kuX9hn0Ru7RyAi94xLPP5mgetkNMcf/i6hLawDTFnQ6sOJJgII+88H3sGZ4B1hK4mlPn+tcNVRlQdIMNEGCBUalwVF5oh9P9DgxwO+RPtK7MwaQuUDwrQ7jB5bJicc/4sKh7bgaurolhVPAzjfsukOUbLOS7DY1Mi0w5PisSTIu/EyViZFa9v4bTjOCQepiw04G0/U5lgMqGQq2ZPXZBhX9HXi5eteiopq2bADQGhCuX1jqTYQ3CTdGFCpqPdTXM0mONOA5tHm2ikrwILKz++p+Kbgjyw5vbPoSjkmQvS9lAll8BYejihu+MuRRypnQ3uhcegTYRjcYwgrHARhUYosOV3s8mxpvUEgzi+BiM+l3buVx0jIybHTJ+JFxP9gBo0QnFs74q9h"/>
</tool_info>
-<tool_info>
</license>
</tool_info>
Enjoy life, just get out there and do it.
Re: Updates
I just renamed "updateOFF.upd " to "updateON.upd " atnd auto updates now works BUT still a message appears when I plug into my car it asks if I want to do an update check. No I don't but either option makes me go back to the start telling me to unplug and update.
How can I start doing the tune install?
Re: Updates
Can anyone help or answer my previous 2 posts?
Re: Updates
click the green check then run the updater on the pc and it will download the file.
If not, post the info.xml file from the intune drive here please.
