2017 GMC 6.2l 8sp
Re: 2017 GMC 6.2l 8sp
Any word on what to do when my Itune is just stuck trying to read the ECM?
did it already prompt you to go to the PC and update using ignition?whoodie22 wrote:Any word on what to do when my Itune is just stuck trying to read the ECM?
ignition in RUN mode?
Yes, it did tell me put key in run position. Then it ask read PCM i say yes then it gets stuck in read mode. It has asked read PCM i hit yes then it ask read TCM and I click no, then it just sits please wait trying to read.
can you post the current info.xml file and anything in the runtime folder on the i2 drive so we can sort this out?whoodie22 wrote:Yes, it did tell me put key in run position. Then it ask read PCM i say yes then it gets stuck in read mode. It has asked read PCM i hit yes then it ask read TCM and I click no, then it just sits please wait trying to read.
Where do I find these files? I looked in the settings and under the ? tab and can't find the info.xml file or runtime folder.
they are in the drive called i2 on the pc.whoodie22 wrote:Where do I find these files? I looked in the settings and under the ? tab and can't find the info.xml file or runtime folder.
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_G" status="0" sn="14U7ZAVXER"/>
-<applications count="5">
<application rev="2r01t" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01l" name="gui"/>
<application rev="missing" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01g" vin="2r01h" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM" tune="2t02zt"/>
</databases>
-<system rev="1r01a" config="1r01d">
<option name="Wifi" enabled="false"/>
</system>
<last-connected vin="3GTU2NEJ3HG194637" mfr="GM" calid="12677878, 12678704, 12678681, 12667480, 12667660, 12667714, 12667806, 12679747"/>
<last-connected calid="24283721, 24283176, 24283173, 24272181, 24274482, 24283178"/>
<licenses tuned="0" available="1"/>
<update request="true"/>
<reg reg="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"/>
</tool_info>
-<tool_info>
</applications>
</databases>
</system>
</tool_info>
The runtime folder has 24 files in it but I can't copy and paste them nor drag them over. I tried opening them and it says Windows can't open this file.
please email them to zhill <@> powerteq.comwhoodie22 wrote:The runtime folder has 24 files in it but I can't copy and paste them nor drag them over. I tried opening them and it says Windows can't open this file.
It is on the way now.
From Jason Starks
From Jason Starks
Did you receive my email? Just want to make sure you got it not rushing.
canyou attach the info.xml file from the i2 drive here so we can check it out?
use the attach file option below when you are replying here.
I attached it to the email as well.
mikel wrote:canyou attach the info.xml file from the i2 drive here so we can check it out?
