Page 21 of 30
Re: 2015 Eco Boost Dead peddle Info Thread.
Posted: Fri Nov 20, 2015 10:11 am
joic0205 wrote:hi matt can you also send me a custom tune for my truck i also get the dead pedal right away like 3 or 4 miles after i install it
you'll need to post a copy of your backup file please.
Posted: Fri Nov 20, 2015 10:33 am
by DiabloMatt
sqeegee wrote:Matt,
here is my 87 test tune, going on 11 days, 975 miles and no issues. You could make me a 91 test tune to try.
here you go
Posted: Fri Nov 20, 2015 10:38 am
by DiabloMatt
MR. SEEDS wrote:Mind if I get a custom tune too? Or a test tune to try? I downloaded the latest update, put in in the truck and immediately had the dead peddle.
here you go.
Posted: Fri Nov 20, 2015 10:41 am
by DiabloMatt
Scheibel wrote:Hey Matt,
I tried the 91 octane tune you made for me after work today and had no luck. It could be due to the fact that my backup was created last week after you released the new CROM and I since unmarried my tool to go to the dealership on Monday. I had to remarry it before I could install the custom tune you wrote for me today. I'm not sure if that new backup created differs from the old backup and is creating the problem.
It also might be worth noting that since I've had the tool I've never had any trouble running the modify stock tune.
For reference I'm going to attach my old backup, the off the shelf 91 tune that failed, the 91 custom tune you wrote for me, as well as my new backup and the modify stock tune that is working with no dead peddle. Hopefully there will be some info in there that will help.
Also, if you could send another custom tune my way (either 87 or 91) I can give that another try; would love to get something working.
Scott
here you go... try this one.. :)
Posted: Fri Nov 20, 2015 12:27 pm
by Roiceed
How do you remove the speed limiter on these tunes? Cause it only goes to 125 like this.
Posted: Fri Nov 20, 2015 12:33 pm
by DiabloMatt
Roiceed wrote:How do you remove the speed limiter on these tunes? Cause it only goes to 125 like this.
that is a good experament actually.. can you use the adjustable peramters in the tool to change the custom tune? im curious if that "breaks" the tune. give it a shot for me if you can :)
Posted: Fri Nov 20, 2015 12:48 pm
by Scheibel
Scott
Thanks Matt! Made it to work with no dead pedal....I'll keep you posted on whether it continues to work.
Posted: Fri Nov 20, 2015 2:17 pm
by joic0205
How can i post the copy of my backup file can you help me out im new to this
Posted: Fri Nov 20, 2015 2:50 pm
by DiabloMatt
joic0205 wrote:How can i post the copy of my backup file can you help me out im new to this
what tool are you using?
Posted: Fri Nov 20, 2015 3:24 pm
by DiabloMatt
Scheibel:
can you do me a favor and flash in the flirst tune i sent you (custom_91_performance) that you said killed the pedal. and if it does kill it (i am to assume it will again) can you download the "last tune written" out of the tool and post it please. then flash the tune that DOES work and again download and post the last tune written again? that would be a HUGE help for me.
anyone else that has some time could you do it today as well? im trying to get a trace on this.
basically for you other guys. load the caned tune. post up last tune written. then put your custom back in of the same octane and after it flashes post up the last tune written again. just change the name slightly so i can tell the difference. please please please.
Posted: Fri Nov 20, 2015 3:56 pm
by Scheibel
DiabloMatt wrote:Scheibel:
No problem Matt. Fyi, I won't be able to post it till tonight though.
Scott
Posted: Fri Nov 20, 2015 4:11 pm
by DiabloMatt
Scott
thats fine. do me a favor though. send them both to my email then. [email protected]
thank you so much
Posted: Fri Nov 20, 2015 5:28 pm
by juangorena
MATT CAN I TRY THE 91 PERFORMANCE TUNE ? attached are my last files
Posted: Fri Nov 20, 2015 5:57 pm
by DiabloMatt
juangorena wrote:MATT CAN I TRY THE 91 PERFORMANCE TUNE ? attached are my last files
here you go sir :mrgreen:
Posted: Fri Nov 20, 2015 6:03 pm
by Roiceed
Ive changed the speed limiter in the custom tune the first time i installed it, ive driven over 1500 miles on it since then, no issues. Gas mileage is a little disappointing though, and im saying the gas mileage when im driving for gas mileage. I do not see a gain there. When the update finally gets Dead pedal proof, will there be a gas mileage option? I know there wasnt a gas mileage tune in the first 10 updates or so.
But other then that, I like breaking the tires loose at 40 thats pretty fun, I havent found any Chargers or Challengers to race yet tho lol
