Page 21 of 33
RE: PE adjustments
Posted: Mon Dec 28, 2009 5:10 pm
by jlosh20s
im still not seeing anything to do with the injectors in the pid's
RE: PE adjustments
Posted: Mon Dec 28, 2009 5:19 pm
hmmm... well, if you don't have any fuel injector parameters to log, then there's no way for you to tell what your injector duty cycle is at...
interesting...
RE: PE adjustments
Posted: Mon Dec 28, 2009 11:10 pm
by jlosh20s
are you interested tuning my truck i could even send you the tune its running now?
RE: PE adjustments
Posted: Mon Dec 28, 2009 11:42 pm
send me everything I'd need and I'll take a look at the files... if there's anything I can do, I'll letcha know, and we'll go from there...
I need a copy of your stock original backup tune file, and also a copy of the current tune that's in your truck right now (the Last Tune Written)
sound good??
RE: PE adjustments
Posted: Tue Dec 29, 2009 1:36 am
by jlosh20s
sounds good sending info now
RE: PE adjustments
Posted: Wed Dec 30, 2009 8:16 pm
by jlosh20s
lew is the man he did in one try what my other tuner has been trying to do for 2 months he knows his sh@t when it comes to tuning with a diablo tuner
RE: PE adjustments
Posted: Wed Dec 30, 2009 8:27 pm
thanks man!!
Posted: Sat Jan 09, 2010 9:42 pm
by steeleshark2
bump!!
Posted: Mon Jan 25, 2010 2:25 pm
by steeleshark2
Bump!!
Posted: Sun Jan 31, 2010 4:51 am
by fernanbfg
Lew,
I last posted at "efan control for 2004 Silverado with u7193".
I finally got out on the freeway today (went to Monster Jam in PHX) and did some logging. Ran the numbers through DSLogRedux and it came up with LTFT Bank 1 (12.71401%) and LTFT Bank 2 (11.79003%). I am going to lower the slope to -13%. I attached the log, before adjustments. My only worry is that there may be too much fuel and cause knocking at lower RPMs.
It's an 04 Yukon with K&N 77 Series CIA and Magnaflow cat-back (single).
It already experiences knock between 3500 - 5000 RPMs when at WOT.
I'll lkeep you posted.
Posted: Sun Jan 31, 2010 10:14 am
if your ltft's are at +11 and +12 now, then that means you're pretty lean, which is why you're probably knocking at WOT...
so, adjusting your slope to -13% to get your fueling straightened out will be fine...
Posted: Sun Jan 31, 2010 6:32 pm
by fernanbfg
Well the injector slope adjustment seemed to cure the knock, but I still need to drive it a little more and then do a log.
I did notice that that a little more throttle is needed for the kick down from 4th to 3rd (40 - 45 Mph). The lugguing is a little more evident.
Datalog not working?
Posted: Sun Feb 14, 2010 8:25 pm
by CyberGreyVette
I just bought a new Diablo Predator for my 2009 Vette. I installed the Performance tuneand drove it for about 115 miles. I decided it was time to do a data log to see what adjustments I may need to make.
I have version U7194.
I Follow Lew's directions and attempted the log the following items:
air/fuel
command throttle
engine speed
intake air temp
longterm fuel trim bank (1&2)
MAF Sensor
Spark Advance
(couldn't find Throttle Knock Spark Retard in there)
I got on the hwy and did the view/record and it only logged about 2 min worth of data before it was full. I thought that was only an issue on the older models. Anyone know what the heck is wrong with this thing? I bought the newest version to make sure I wouldn't have any problems.
RE: Datalog not working?
Posted: Sun Feb 14, 2010 8:29 pm
yeah, just download the log to your pc using the dataviewer program...
Posted: Sun Feb 14, 2010 9:46 pm
by CyberGreyVette
Yeah, I figured that part out finally. The dataviewer so far just says I need to adjust Inj Slope UP by 2% (+2) & make a PE Adjustment -2 %. But my main concern is, is 3 min worth of data logging enough to go on? So far I just adjusted the Slope...not sure I'f I'm suppose to adjust the PE based on the hwy cruise log, do you know? Do I need to do any data logging at WOT?
