Latest Intune release here.
I'm feeling like a moron … I have the Macbook Air and was told that the InTune is compatible. I've gone through all the forums on your website and it sounds like a foreign language. I hooked up the new InTune and it showed two updates; which I have no idea how to "update". Someone says, "drag it over" … and I say "huh?".
Please help.
Thanks!
Rich
Plug the InTune into my Jeep and then send you the file? Please, treat me like a moron and give me the step-by-step.
Please help.
Thanks!
Rich
copy/paste or drag/drop the files from your Mac to the drive called intune to load the updates.
just got intune for my 2004 mustang v6, cant get it to communicate with computer. intune wont update
HotRod Dan
He a customer trying to do auto update but nothing shows it was done
- 1187014_1377321782499789_2131722359_n.jpg (99.69 KiB) Viewed 7418 times
Ok I downloaded the updates but they loaded in the wrong order so now it load the other update it the intune. What do I need to do? Delete it out? if so how do you delete updates.
i just bought the intune for my 2006 silverado i dont see the settings to change for a gear change
gear ratio, or axle ratio.. when you go into Modify the tune, it should have one of those items listed... it may be under Speedo Calibration...
capnallthat
Why cant I update it just keeps going to product register then says im already registered?
Ross Smith
Greetings,
Just received, registered and updated my new Intune.
Question: My available install options do not include any 93 Octane Tunes.....why?
the 93 tune is likely listed as the Diablo tune.
Hello, we have the RIPP Supercharger with your tune on a 2014 JK. we are in a cold climate, we just installed the tuner and everytime we get up to 3000 rpms the check engine light comes on, and in red back wards parenthesis pop up with a lightning bolt in between them, the jeep falls flat on its face with power. if we turn the key off, then back on, the red lights goes away, power is fine but the engine light stays on. What do you think?
Just received my tuner and I'm not sure if my PC isn't detecting it or if it already has the latest download. Using this for my '14 Dodge Charger. Info from my tuner is below. Can someone tell me if this needs an update? Thanks.
Application: 1r04d
DCX Tune Db: 1r01q(*)
DCX PID Db: 1r01b(*)
FORD PID Db: 1r01b(*)
GM PID Db: 1r01a (ok)
DTC Db: 1r01a(*)
VIN Db: 1r01d(ok)
Info Db: 1r01b(*)
Version: 1r04d
Born: 8/15/2014
Application: 1r04d
DTC Db: 1r01a(*)
VIN Db: 1r01d(ok)
Info Db: 1r01b(*)
Version: 1r04d
Born: 8/15/2014
for your 2014 Dodge charger?
You need to buy the inTune DCX tool for that car.. the inTune i-1000-DCX...
the regular intune i-1000 will not work on that 2014 dodge...
06MonteSS wrote:for your 2014 Dodge charger?
guinner16 wrote:Just received my tuner and I'm not sure if my PC isn't detecting it or if it already has the latest download. Using this for my '14 Dodge Charger. Info from my tuner is below. Can someone tell me if this needs an update? Thanks.
Application: 1r04d
DTC Db: 1r01a(*)
VIN Db: 1r01d(ok)
Info Db: 1r01b(*)
Version: 1r04d
Born: 8/15/2014
Thats what I have - Intune I-1000-DCX. Is this not the right section of the forum?
I have the 1000 DCX and it keeps telling me I need to update software which I have several times when I try to install it in my 2014 Dodge Ram 1500 5.7 Hemi. It also says the vehicle is not supported. I called Diablosport and waited on hold for about 20 minutes and was told I need to do a calibration update???
