LS1/LS2/LS3/LS4/LS7 etc. - LOGGING, ADJUSTING INJECTOR SLOPE
calbert
Post by calbert »
Frustrated.
Inj. Slope set to -6%, vehcile feels like it's running on sludge instead of gasoline. Will new log show something else, or will PE's need adjustment now? Help!!!!
what are you doin man?? what was the slope set to before??
post up the log file...
calbert
Post by calbert »
06MonteSS wrote:what are you doin man?? what was the slope set to before??
This is the log I used to get results from DSLogRedux.
before you set the slope to -6... what was it set to before, anything? did you adjust it at all before??
calbert
Post by calbert »
No. Didn't make any adjustments prior. But, I did tune with the Diablo 93 Octane Tune, and I turned off Spd. Limiter / and increased Rev. Limiter to the max which was 400.
k... then the -6 adjustment sounds fine.. should definitely not make it feel like a slug... should be better... quicker response, etc etc...
when you made the adjustment, did you select the Diablo Tune - the modify parameters??? or did you select a different tune by mistake?? choosing the wrong tune would account for the reason why it feels sluggish now...
calbert
Post by calbert »
I chose the Diablo Tune, and Modify parm. Do you think I should?
Reset back to factory tune,
Re-apply Diablo tune
Turn off limiters again
Re-log data,
DSLogRedux again
Re-set Slope
post up copies of your original backup stock tune file, and also a copy of the "last tune written" tune file...
tradociii
2011 Camaro Donation made
Post by tradociii »
So now I have made my donation, how do I get the download? I know you don't send it, but ht ethird party will???? Tra
RE: 2011 Camaro Donation made
huh???
for what?? dslogredux??
you can get it from the site here: http://www.dslogredux.com/download.html
ChevyBoy03
Post by ChevyBoy03 »
I have an 03 silverado with a diablo predator u7193 and im trying to log the parameters to get the diablew tune but i cant find spark knock or the air fuel ratio what can i do... And does the diablew tune make a big differece i want my truck to fly its a single cab silverado with the 5.3 in it please help
you will not have Air Fuel Ratio on that model predator... so don't worry about that one...
nor will you have "Total knock spark retard"... instead, you will have and need to log "Knock Retard"
and yes, the custom tune will make a difference... over and above the regular included tunes... ;-)
ChevyBoy03
Ok thanks I will log that today.... How long will it take to make the custom tune?
if I get everything I need... I can usually have it done and back to ya the same day... ;-)
if something comes up with the wife and kids tho, it'll be the next day... hehe...
info about everything I need can be found here http://www.diablewtune.com
ChevyBoy03
i just sent you everything and sent the money
