Page 24 of 33
Posted: Fri Jun 18, 2010 11:37 am
by calbert
Frustrated.
Inj. Slope set to -6%, vehcile feels like it's running on sludge instead of gasoline. Will new log show something else, or will PE's need adjustment now? Help!!!!
Posted: Fri Jun 18, 2010 2:27 pm
by 06MonteSS
what are you doin man?? what was the slope set to before??
post up the log file...
Posted: Fri Jun 18, 2010 3:05 pm
by calbert
06MonteSS wrote:what are you doin man?? what was the slope set to before??
This is the log I used to get results from DSLogRedux.
Posted: Fri Jun 18, 2010 3:12 pm
by 06MonteSS
before you set the slope to -6... what was it set to before, anything? did you adjust it at all before??
Posted: Fri Jun 18, 2010 3:20 pm
by calbert
No. Didn't make any adjustments prior. But, I did tune with the Diablo 93 Octane Tune, and I turned off Spd. Limiter / and increased Rev. Limiter to the max which was 400.
Posted: Fri Jun 18, 2010 3:28 pm
by 06MonteSS
k... then the -6 adjustment sounds fine.. should definitely not make it feel like a slug... should be better... quicker response, etc etc...
when you made the adjustment, did you select the Diablo Tune - the modify parameters??? or did you select a different tune by mistake?? choosing the wrong tune would account for the reason why it feels sluggish now...
Posted: Fri Jun 18, 2010 3:36 pm
by calbert
I chose the Diablo Tune, and Modify parm. Do you think I should?
Reset back to factory tune,
Re-apply Diablo tune
Turn off limiters again
Re-log data,
DSLogRedux again
Re-set Slope
Posted: Fri Jun 18, 2010 6:49 pm
by 06MonteSS
post up copies of your original backup stock tune file, and also a copy of the "last tune written" tune file...
2011 Camaro Donation made
Posted: Tue Sep 21, 2010 6:58 pm
by tradociii
So now I have made my donation, how do I get the download? I know you don't send it, but ht ethird party will???? Tra
RE: 2011 Camaro Donation made
Posted: Wed Sep 22, 2010 3:04 am
by 06MonteSS
huh???
for what?? dslogredux??
you can get it from the site here:
http://www.dslogredux.com/download.html
Posted: Mon Nov 01, 2010 11:40 am
by ChevyBoy03
I have an 03 silverado with a diablo predator u7193 and im trying to log the parameters to get the diablew tune but i cant find spark knock or the air fuel ratio what can i do... And does the diablew tune make a big differece i want my truck to fly its a single cab silverado with the 5.3 in it please help
Posted: Mon Nov 01, 2010 12:38 pm
by 06MonteSS
you will not have Air Fuel Ratio on that model predator... so don't worry about that one...
nor will you have "Total knock spark retard"... instead, you will have and need to log "Knock Retard"
and yes, the custom tune will make a difference... over and above the regular included tunes...
Posted: Tue Nov 02, 2010 10:44 am
by ChevyBoy03
Ok thanks I will log that today.... How long will it take to make the custom tune?
Posted: Tue Nov 02, 2010 1:41 pm
by 06MonteSS
if I get everything I need... I can usually have it done and back to ya the same day...
if something comes up with the wife and kids tho, it'll be the next day... hehe...
info about everything I need can be found here
http://www.diablewtune.com
Posted: Tue Nov 02, 2010 11:21 pm
by ChevyBoy03
i just sent you everything and sent the money
