still says must be registeredDiabloMatt wrote:2015bluef150 wrote:attached
drop this on your intune drive please. that should allow you to update it.
2015 Eco Boost Dead peddle Info Thread.
2015bluef150
Re: 2015 Eco Boost Dead peddle Info Thread.
DiabloMatt
2015bluef150 wrote:still says must be registeredDiabloMatt wrote:2015bluef150 wrote:attached
wtf... hold on one sec
Did the file disappear from the drive? if so, the tool should now be registered. Please post the info file for me one last time, a fresh copy please. I'll double check that the registration was done successfully. Be sure the update isnt in the drive while you're trying to update the registration.
2015bluef150
Yes - the file disappeared. fresh copy of info file attached.garrett wrote:Did the file disappear from the drive? if so, the tool should now be registered. Please post the info file for me one last time, a fresh copy please. I'll double check that the registration was done successfully. Be sure the update isnt in the drive while you're trying to update the registration.
- info.xml
- (1.71 KiB) Downloaded 353 times
I'll try out the updated file tonight. Please disable the start/stop for us 2.7l owners.
No dead pedal on the last update; however, there is a wrench and limp mode if revved all the way to redline. The wrench goes away after a restart and will not turn on if you only rev up to about 5k, but if you rev it up to 6k it will come back on.
So far no check engine light or fault codes, but the previous revision did give me an overboost fault (91 oct) after the wrench, so I'm assuming this one is the same issue.
instant dead pedal with the updated crom file installed........
here are the original backup and diablosport 87 tow tune
kicker300zx
Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
- PCM_68192895AH_Backup.drg
- (121.55 KiB) Downloaded 298 times
- PCM_68192895AH_LastTuneWritten.drg
- (121.55 KiB) Downloaded 304 times
Since loading 91 canned "ee" tune on friday ,working great 4 heat cycles, 15 key cycles, 400 milessqeegee wrote:Put 91 test tune back in, plasma core at normal, all is goodDiabloMatt wrote:ok thank you very much.
you have been a huge help
were you able to put the custom tune back in it and have it work ok?
this is the first canned tune that went for more than 10 miles
amazing low end torque and keeps pulling strong
DiabloMatt
sqeegee wrote:Since loading 91 canned "ee" tune on friday ,working great 4 heat cycles, 15 key cycles, 400 milessqeegee wrote:Put 91 test tune back in, plasma core at normal, all is goodDiabloMatt wrote:ok thank you very much.
good deal!!!!!
kicker300zx wrote:Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
could you post your info.xml file please
options/show information, what is the version?LAFNGAS wrote:instant dead pedal with the updated crom file installed........
post your info file please.kicker300zx wrote:Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
kicker300zx
mikel wrote:post your info file please.kicker300zx wrote:Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
- info.xml
- (1.93 KiB) Downloaded 301 times
the tune filkes you posted earleir were from a Dodge, can you load the tunes to the F150 and post the files from that truck please?kicker300zx wrote:mikel wrote:post your info file please.kicker300zx wrote:Updated the I2 with the supplied update. Updated using the can 87 Tune and got instant dead pedal.
kicker300zx
I tuned my jeep months ago. i have tuned my f150 probably 10 times since then. plus i took the tune off my jeep when i was helping with the f150 problem. i have no idea why its showing the jeep files. it was the only files showing. that is weird.
I will tune my truck on my lunch and report the files.
