Page 4 of 17
RE: o4 avalanch speedometer
Posted: Fri Feb 06, 2009 2:28 pm
by m8silverado
Heeeellllloooo. Is this really a help or just a place to type and try to vent?
Posted: Fri Feb 06, 2009 5:06 pm
You should have an email from our rma department, but here is the RMA info:
DiabloSport
ATTN RMA # 8519
3500 NW Boca Raton Blvd Suite 508
Boca Raton, Fl 33431
Posted: Fri Feb 06, 2009 5:18 pm
by m8silverado
Thanks pal, really appreciate it!!!
Posted: Sat Feb 07, 2009 5:54 pm
by cowboytavito
hello guys:
i heve a u7194 for my chevrolet silverado 08, but i cant delete the speed limit in the option speed limit 1 and 2 and on -off.
how can delete speed limit
thank you.....
RE: Hardware upgrade program
Posted: Mon Feb 09, 2009 8:59 pm
by zz50
If it is any consolation I recieved a confirmation quickly last month but was told they are very busy and the time frame was much longer now for the upgrade. Miy timeline is at a month now and no idea as to the status.
RE: Re: RE: just purchased my u7192
Posted: Sun Feb 15, 2009 10:49 am
by Gitingrdone
I have a 2006 GMC sierra and a u7192 tuner. The serial # is 001420. The software rev: 2.00 and Hardware rev: 1.01. Also when it starts up the number it displays is Bios V-6.01. IS this tuner elligiable for an update? Ive also noticed that the top speed limiter will not change no matter what i program it to.
Posted: Sun Feb 15, 2009 11:16 am
by 06MonteSS
yes, you can send that predator in to get it updated...
Posted: Thu Feb 26, 2009 2:48 pm
by spikeyjohnso
My situation is/was a unique one. I sent my U7198 in for the upgrade and found Brian rather easy to get in contact with. My problem began when I asked him to put a rush on as I needed it back sooner than they were ready to ship it. Turnaround was more than 14 business days, I believe, but Brian did get it out sooner than later, at my request. Upon receipt of my upgraded Predator, I found that it had no program in it. Brian found an engineer to write one for download. New problems present inability to erase codes on my other OBDII CAN compliant GM vehicle. MPH are not present for vehicle speed, instead it is in KMH. And as of this point no Hi octane tune, although Mike L tells me it's there. I have seen a noticeable improvement with the stock 87 octane tune so I can live w/that. But, had to go out and by a code reader for something I was previously able to do w/my Predator, prior to upgrade. Also, I have yet to find any benefit from the data readers as my unit does not show A/F ratio and I did not need anything to read my LTFTs.
Posted: Thu Feb 26, 2009 3:03 pm
by CANUCKPREDATOR
You do realize that your LTFTs are for part throttle driving, which for most people is 99.99% of what they do. The A/R ratio is only an issue when you are at WOT. There are quite a few GM vehicles that don't report the A/F ratio either. What do you drive?
Posted: Thu Feb 26, 2009 3:19 pm
by 06MonteSS
his 7198 will not report the AFR on the predator screen... would have to log with a laptop and the dataviewer to have the AFR parameter available...
also, the KMH is what it displays on the screen - my 7191 does that too, but in the data logs you save, it will be correct MPH values instead... well, at least mine is...
Posted: Wed Mar 04, 2009 4:19 pm
by m8silverado
How long does it take to get the tuner back? Mine has been gone almost a month. Just curious as driving sucks without it once you're used to having it!
Posted: Wed Mar 04, 2009 4:50 pm
by mikeremax
I had mine back within 30 days.
Posted: Tue Mar 10, 2009 4:49 pm
by m8silverado
Hello Mikel, Ifinally got my updated tuner back. Thanks! You guys have excellent products and services but I have one question. It cost me $9 for freight to send the programmer back to you but you guys charged me $26 to send it back to me. Wow freight went up 30 days! Thanks for the great products though.
Posted: Fri Mar 27, 2009 6:44 pm
by CLTTZR
how do you know what U719x model you have?
Posted: Fri Mar 27, 2009 9:53 pm
by 06MonteSS
what year, make and model vehicle do you have??
