Page 4 of 4
Posted: Mon Nov 10, 2008 9:54 pm
by grngt50
keep backing off timing until the pinging stops, that's all you really can do for now. Are you sure you don't have a really bad vacuum leak somewhere? Was your manifold installed correctly? A bad vacuum leak will cause bad pinging because the engine is ingesting unmetered air and cant make the appropriate changes to the fuel supply
A good way to check for vacuum leaks to start your engine, open the hood and spray some carb cleaner around the suspected area. If you hear the rpm's rise, then that's a good sign you've got a leak somewhere.
Other than what we've been trying, if you still can't get it right then you might have to end up taking it to a shop with a dyno/wideband. If you lived closer I'd be able to help you bro, best of luck
Posted: Tue Nov 11, 2008 1:16 am
by lazorrazor
Sounds like you have a problem with a few things, I would spend a few bucks and have the car put on a scope at a reputable shop, you might have a vacum leak at the manifold, your timing might also be off, do you know if the car has any pully mods or other mods not mentioned? Once again, get the car into the shop so you can get this resolved before you damage the engine.....better to be safe then sorry!
Posted: Tue Nov 11, 2008 1:32 am
by LuisMunoz
the guy that installed it is really good and really knows what he is doing im pretty sure it was done correctly but ill check it anyways just to be sure
no no pullys in the car that stuff is still stock
Well thanks for all the help and all the replys from everybody really appreciate all the help!!!!
ill update as soon as i get it figured out and let you know how i fixed it just in case anybody else has this problem, which is really frustrating by the way
Ill take it to a shop tomorrow or to a ford dealer and see what they tell me about the car
Once again thanks alot!!!
Posted: Mon Nov 24, 2008 1:03 pm
by LuisMunoz
Ok guys just an update, I finally figured out what my problem was, turns out one of my lifters was not working properly, a simple oil change with some heavier oil fixed everything car runs GREAT and REALLY FAST :mrgreen:
Thanks for all the help guys!!!!!!
