U7137 beta update
Wolfman
RE: U7137 beta update
Is this beta better than the last update for 03's? If so can you email me the beta and instructions on loading into my 7137.....then I'll try the can tune for 87 oct and give you some feed back......
The rpm's are at what rpm a downshift will be allowed based on at what %tp you are at.need-a-cage wrote:Johan,
I am not exactly sure what the downshift 2-1 and 3-2 rpm is referring to. Is that the rpm that it has to go down to in the higher gear before it will downshift, or is the target RPM for the gear it is shifting into?
Also, can you tell me how much you changed the part throttle upshifts, or will I have to "modify stock tune" to see what they were?
Thanks,
Craig
I did not change the part throttle upshift points in the tunes, did something else.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Have not given up but have put it to the side for now due to some other stuff that needs some attention.Harmwalker wrote:Johan-
Are you guys still trying to add downshift parameters to the 07's or have you given up due to the complexity mentioned before?
If you want hit me up via e-mail with your last tune written and ill set something up for you.
Diablosport INC
Diablosport INC
Everything was working great on the 9T03a. I found the partial up shifts to be the biggest improvement. The adjustability for the different throttle openings will prove to be valuable for fine tuning. I will now try the the 9T03c and report back on the results. More of this latest update in the direction you have taken should be a good thing. Thanks for continuing to improve this product. It is performing better than I had anticipated.
2007 Hemi Quad 2WD Sport
Bilstiens, Front/Rear Bell tech Sway Bars
Rear Level Kit
Predator!
Kern Valley CA
Rear Level Kit
Predator!
Kern Valley CA
Johan, installed 9t03b and found it a little sluggish then installed 9t03c and found it to be better, this tune seams a little safer then the 02 tune, the 02 had better gas mileage but was plagued with spark knock, I think 03c is the ticket, now I just need some trans adjustability, thanks for the hard work!
04 blk QC HEMI RAM, Flowmaster exhaust, Predator, K&N air filter, 500 watt Pioneer sound system, Cooper Zion Ltz's.
Harmwalker
Yeah Johan I will hit you up with that email later. Do I just use the DS downloader to upload the last tune written into my computer so I can email it to you?johan wrote:Have not given up but have put it to the side for now due to some other stuff that needs some attention.Harmwalker wrote:Johan-
As far as the new adjustments on the 9t03c I think they're great. Love the new tranny shifts and the partial throttle upshift adjustment. I set my upshifts to +200 RPM's for each throttle position and I love it. Thanks for all of the hard work.
2007 Ram 1500 QCSB 4x4 5.7L HEMI Pearl Black
Magnaflow Dual Cat-Back Exhaust
Diablo 91oct Tune
Big Vararam CAI
Poweraid TBS
Wife's Ride - 2008 Charger SXT AWD 3.5L HO 24-Valve V6 - TorRed
Diablo 91oct Tune
Big Vararam CAI
Poweraid TBS
need-a-cage
Okay, so I am assuming that it is the rpm of the gear you are currently in.johan wrote:The rpm's are at what rpm a downshift will be allowed based on at what %tp you are at.need-a-cage wrote:Johan,
Thanks,
Craig
Now, I adjusted the 3-2 45% point to 3k and it is now downshifting at well under 45% throttle like it should. So, how does this relate to throttle positions under 45%? Does it interpolate between this point and some other point in the table below the 45% point?
Thanks,
Craig
06 QC SLT Big Horn Hemi 2wd 20's,3.92's, Magnaflow, custom Y, Diablo, Edelbrock Shorties, modified K&N CAI.
14.64 @ 90.5 mph (short belt, no spare)
93 Stroked and Blown Mustang
10.84 @ 128.5mph
10.84 @ 128.5mph
Are you actually logging throttle position?need-a-cage wrote:Okay, so I am assuming that it is the rpm of the gear you are currently in.johan wrote:The rpm's are at what rpm a downshift will be allowed based on at what %tp you are at.need-a-cage wrote:Johan,
Thanks,
Craig
Thanks,
Craig
What you think may be 45% and what the TPS hows as 45% may be different.
need-a-cage
Okay, so are you saying that it does not interpolate below 45% so it should never downshift from 3rd to 2nd at throttle positions below 45%?
If that is the case, then you need to change the 45% in the table to something more like 25%. You don't need 45% and 55%. That is a very small change on the pedal.
I did not log the TPS. What do I log to see the throttle position %.
After driving it more, it does take a little more throttle to downshift than I originally thought. However, I think that is at higher speed. At really low speed like 15mph it seems to downshift with less than 45% throttle. This was my biggest complaint and it is definitely better when I changed the 3-2 downshift RPM to 3000, so I really think that it is interpolated values for the shift point rpm vs. TPS below the 45% point that I adjusted.
When I get a chance, I will up this to 4500 rpm and see if it takes even less throttle to provoke a 3-2 downshift. If it does not interpolate for lower rpms and throttle positions, then changing this parameter would do nothing until it got to 45% throttle.
10.84 @ 128.5mph
10.84 @ 128.5mph
