05 avalanche 2500 8.1---"vehicle not in database"
Christopher, please try this update and see if it has support for your truck:
- u7193-9t08e.crom
- (927.53 KiB) Downloaded 140 times
when you say same thing...what do you mean?ckeene wrote:tried 9t08e againjust to double check, same thing
thanks for the try though
still unsupported?
Sounds like it is not loading correctly, let me email it to you....
I have them working on a new update now...ckeene wrote:installed on tool . does same thing as 9r07
only tunes on there is modify stock hp, and orginal back up. tried to change tire size and it says i need a free download.
Auto Connect is ENABLED.
Legacy Connect is DISABLED.
A tool was found on COM4 at 115200 baud.
XML RPC commands are AVAILABLE.
XML RPC protocol version is 1.60
Tool type = 'Predator'.
Serial number = '218120350'.
Part number = 'u7193'.
CROM version = 'u7193-9t08e 10/08/2009 02:11:41 PM boot4'.
Vehicle VIN = ''.
Vehicle Calibration = ''.
Origional backup NOT saved.
Tool is Married FALSE.
Single user tool FALSE.
Using Class2 Protocol FALSE.
Calibration Updates are NOT supported.
A Calibration Update is NOT required.
XML RPC WILL be used for FRG transfers.
Tune compression is AUTOMATIC.
Tune compression is set to ENABLED.
Tool registration is NOT supported.
Tool does NOT support multiple ECUs.
Config INDICATES multiple ECUs.
Tool reports 1 ECUs.
Vehicle VIN = ''.
new crom sent....
