U7194 update, again...
CANUCKPREDATOR
RE: Re: Poblem with new Crom.
Post by CANUCKPREDATOR »
i wouldn't sweat 2-3 mph, that's pretty darn close.
rjaro7
Error code (-14,-15)
Post by rjaro7 »
2007 2500hd nbs cal id 12622161
2010 GMC Sierra 5.3 Flex
killerrf
Post by killerrf »
mines doing the EXACT samething as Sparks' predator shows. wont read stock program.
2008 chev 5.3l flex fuel.
johan
Post by johan »
Ok, luckily we have a vehicle here that is doing what you guys are seeing so it should get taken car of today.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
SparkySparks
Post by SparkySparks »
Hope everything is going good with the fix, can't wait to get the tune back in the truck and dialed in.
johan
Post by johan »
http://www.diablosport.com/downloads/pr ... 9t08p.crom
New one with the -14/-15 error backup fix as well as calid support added for the files sent to me from you guys.
Diablosport INC
WOOHOO!!!
concoursd
Post by concoursd »
that was fast turnaround
therink
Post by therink »
greeeaaat service, I will give it a try and post results
therink
2012 Silverado 3500 HD LTZ, Z71, crew cab, 4:10, 6.5 box, Stock 6.0, K&N drop in
killerrf
Post by killerrf »
the new crom file works for me now.
it read stock program and uploaded the new programming.
no problems. worked like it should. just have to take the truck for a rip to see how much better it runs.
thanks.
jjdeere9620
Post by jjdeere9620 »
Well I downloaded rev 08 into my 7194 then connected to my pickup and it stored my original backup fine and installed the 87 octane program and the truck was running great. Then my battery started going dead. So I installed the original program back in and it killed my truck!!! It said to service engine, service stabiltrak, service 4-wheel drive and so on and was stuck in third gear. I'm not 100% sure that the revision had any thing to do with it but I thought I should let you know. If you have any input it would be greatly appreciated. thanks
09 Chevy Sliverado LT 4X4 5.3L 6 speed auto "M" series engine
liebemshats
Post by liebemshats »
I downloaded the new crom and the -14/-15 error backup issue is fixed. I made a backup of the stock tune and uploaded the Diablo tune with modified parameters (DoD and speed limit disabled) into the truck. No problems so far. Did a little test run and the truck runs great. Will do a longer testrun tomorrow.
To quote 06MonteSS: WOOHOO!!!
Thanks guys!
08 GMC Sierra Extended Cab 5.3 Corsa Dual Cat Back Exhaust K&N CAI DiabloSport Predator
therink
Post by therink »
All I can say is WOOHOO!! I am impressed with the service and attention I received to fix the -14/-15 issue. My Silvy took the new crom w/ no problem. Boy does she scream. So does my truck for that matter.
Thanks Jonah and crew for your response and excellent service. Kudos.
I will run it for a day and do a log.
therink
killerrf
Post by killerrf »
top end seems the same but the bottom end seems to run much better far better than the other croms... where you had to wait till 3500 rpm before it took off.
nice update. thanks for the fix.
SparkySparks
Anyone else try reading and/or clearing trouble codes?
