2010 Camaro SS Speed Limiter (How to remove?)
ednis187
Post by ednis187 »
Holy Shit.
Wow thats fine.
I´ve the SLP Loudmouth II Exhaust and in a view days the The SLP Blackwing full CAI.
And The Predator now, but i dindt come over 250 kph - 155mph
http://www.youtube.com/watch?v=rXr7G_mp3io
ednis187 - custom tune - speed limiter...
EDNIS187:
here's your tune:
you'll need to save that custom tune file to your PC and load that custom tune into your Predator/Trinity, so...
Importing a custom tune into the Predator/Trinity:
1. Open up the DSDownloader and connect the Predator/Trinity to the PC and power it up.
2. Let the DSDownloader auto connect to the tool.
3. On the DSDownloader press the "send tune file to tool" button.
4. You will get a new window asking you to select the file for importing.
5. Browse through your PC to find where you saved the custom tune file, and click it once to highlight it, then click "open".
6. If this is the first time you are sending a tune to the Predator/Trinity, you will get a new window saying "a valid base file could not be found". So you need to click "Yes". (the "base file" is the copy of your original backup tune file that you saved to your pc before.)
7. Now, browse your folders or desktop to look for the copy of your "original backup" tune file you saved before, and click it once to highlight it - then click "open".
8. The DSDownloader will automatically compare these files to determine if they are the same size and of the same calibration.
9. Once it determines the files are OK, it will import the custom tune file to the Predator/Trinity. This will all happen very fast, usually in under 10 seconds.
10. The DSDownloader will tell you that the import was successful, and the Predator/Trinity screen will show/flash "import OK". (this occurs quickly on the Predator/Trinity screen, so you may not see the message.)
11. You may now unhook the Predator/Trinity and go to the vehicle to install the custom tune.
READ "** IMPORTANT NOTE" BELOW BEFORE INSTALLING TO YOUR VEHICLE!
** IMPORTANT NOTE: your Predator/Trinity may prompt you to say that you are changing tunes, and then ask you if you want to "Reset All Parameters?" - make sure you answer/select YES to this question to reset the parameters that you adjusted before. The changes you made yourself before are already in the custom tune, since you copied it out of your car ("last tune written) to send to the tuner. If you select NO, then it will apply your previous adjustments on top of the adjustments that are already in the tune, and it will get ugly. So, if/when it asks you to "Reset all parameters?" - make SURE that you answer/select YES!
You can also still modify the custom tune just like any of the performance tunes.
Do the install just like any other performance tune, and you're good to go with your new custom tune.
ednis187_SpeedLimiter.grg
(57.83 KiB) Downloaded 270 times
ednis187
RE: ednis187 - custom tune - speed limiter...
Post by ednis187 »
Oh my god so fast :P
You are the best.
Thank you so much
I will try it now
Camaro 2SS L99 Black in Black with Black Stripes and Sunroof.
Tune by Diablosport Predator, SLP Loudmouth II, Afterbourner Taillight, Custom Ambientlight, Xenon Side Scoops.
In April: SLP Blackwing full CAI
RedJewel2SS
Post by RedJewel2SS »
06MonteSS wrote:just put your arm out the drivers-side window, and have your passenger put their arm out the other window...
:lol: :lol:
and start flapping! :P
ednis187
Post by ednis187 »
@ 06MonteSS
Thanks a lot.
I drove the Car and the Limiter is away, my speed 170 mph :mrgreen:
Yeah, you are the best
2sscamaro
Post by 2sscamaro »
EDNIS I hope you have some 200 MPH tires to go with the speed limiter increase. Also I would inspect the poly front end clip after each of those high speed runs as it just might get distored and weakened.
RedJewel2SS
yeah their were rumors last year about the front end clip getting distorted at high speeds with pre-production cars, but i think they fixed the problem before production started.
Luttinger
Post by Luttinger »
Hey Monte,
I have the same problem as Ednis. Bought the predator, put the speed limiter off and nothing happend.
Attached you can find my tune (91 octane, gags off, speed limiter off) and my original file.
Car modifications.
JBA Shorties, GM Performance Exhaust and Volant Air Intake
Would be great if you can help me out here.
Thanks,
Alex
Original Luttinger Tune Camaro.grg
(63.01 KiB) Downloaded 244 times
91 Oktan modifild Tune Luttinger Camaro.grg
(3.25 KiB) Downloaded 278 times
dukegsp750
2010 200 mph program
Post by dukegsp750 »
i also have a 2010 camaro and Im trying to get the 155 limiter off. I tried down loading that file, but it says its unknown source and wants me to search internet.
RE: 2010 200 mph program
you can NOT use someone elses custom tune file... tune files are tied to a specific vehicles VIN number and engine calibration ID...
you have to get a custom tune file made specifically for YOUR car, based off of YOUR current existing tune files...
dukegsp750
please write a 200 mph program for 2010 camaro ss
2010 camaro ss1 6 speed manuel u7194 predator 274627 v.9r16
PCM_637084637085_Diablo_Tune_modified.grg
please write a 200 mph progarm for my 2010 camaro ss1. it cuts off at 155
(3.25 KiB) Downloaded 267 times
dukegsp750
other program
2010 camaro ss1 6 speed man 9r16 predato 274627
PCM_637084637085.grg
(63.38 KiB) Downloaded 266 times
here ya go......
Dukeqsp750_200mph.grg
(54.81 KiB) Downloaded 332 times
dukegsp750
You are the best.
Morgoth
Post by Morgoth »
I hope you gave em all the other good stuff lew! Turn em into vette killers!
2004 GMC Sierra 2500HD,496 w Allison 5 spd,Vararam Vr6 and Vr3,Flowmaster 50 series,TD TBS,Amsoil lubes,MSD wires,Edelbrock shocks,U7193Image
