In English please.duster360 wrote:Your tin foil needs to connected to the CBA ground plane to be an effective EMC sheild.
Trinity EMI jamming GPS and Key FOB
Run a wire from the ground(#4 or #5 pin of the ALDL), to your tin foil hat,,I mean sheild. See if anything improves.gizmodo wrote:In English please.duster360 wrote:Your tin foil needs to be connected to the CBA ground plane to be an effective EMC sheild.
I'm leading a team to respin a CBA(circut board assembly) for a Hall effect sensor we make. The sensor as a pretty good EMC sheilding so I picked up a few things from the EE nerd herd.
Needless Torque Calibrations
www.needlesstorque.com
ALDL? Sorry you have to be specific here I just browse the web all day, I'm not one of those fancy engineering types. Will foil be an okay material to test with, or should I try something else?
OBD2 port.
Yeah, what Mike said.gizmodo wrote:ALDL? Sorry you have to be specific here I just browse the web all day, I'm not one of those fancy engineering types. Will foil be an okay material to test with, or should I try something else?
Aluminum is fine as long as you can maintain a reliable electrical connection.
If you had copper foil, you could solder to it.
I tried this tonight and I have come to the conclusion it is the display causing the problem. I wrapped the Trinity in foil and the display separately. I tried the keyfob without grounding either foil ball and the foil seemed to make things worse. I couldn't unlock the doors even while sitting in the car. Next I grounded foil wrapping for both the Trinity and the display to pin 5 of the OBDII port. This accomplished nothing. Next I tried grounding it to the chassis. Still didn't help. Then I tried grounding them to both the chassis and the OBDII port and it still didn't help. Next I removed the foil from the display and tried again. Now I could get the keyfob to work about 1 out of 5 times from about 2 feet away, which is what I have been experiencing all along. Finally I just removed all the foil.
The display is made by One Stop Displays, and the part number is:OSD035TN01 The Trinity has the v6 version which is the touchscreen. I found the datasheet for it (http://cec-mc.ru/upload/techinfo/osd/OSD035TN01.pdf), but I'm not sure I want to try to add grounds to the cable. Maybe you smart EE guys want to take a look.
I'm out of ideas unless anyone has anything else I can try. I suppose I could try running the Trinity without the display to see if that really is the problem. Would that work Mike or could that damage the Trinity?
Not sure, let me see if I can find out on that...
I can confirm that it is display. I turned the Trinity on and got into the "home" screen. My keyfob had very little range. I unplugged display with the unit still powered up. I confirmed the Trinity was still on by connecting a laptop and pulling files off. I had plenty of range with the keyfob with the display unplugged. When I plugged the display back it the Trinity was still on the home screen. The display is certainly appears to be the problem here.
Nightshade
RF interference from LCD displays is pretty common. LCD displays are usually shielded.. I believe it is the CFL back-light that causes it.. throws a ton of RF..gizmodo wrote:I can confirm that it is display. I turned the Trinity on and got into the "home" screen. My keyfob had very little range. I unplugged display with the unit still powered up. I confirmed the Trinity was still on by connecting a laptop and pulling files off. I had plenty of range with the keyfob with the display unplugged. When I plugged the display back it the Trinity was still on the home screen. The display is certainly appears to be the problem here.
there is non-conductive coated foil out there for this sort of thing.. could stick it to the back of the display and ground it if it's missing the RF shield.. if the shield is in place, make sure it's grounded properly. will be hard to eliminate it if it's a poorly designed LCD panel.. you can't exactly create a Faraday cage if you need to still see the screen.
Hopefully Diablosport can look into this further... maybe they can engage their LCD vendor and come up with some sort of a fix...
The LCD they use is longer available. It appears as though OSD has replaced it with a new one. As for the shielding, there is some type of metal around the back of the LCD, but I don't know if that is to protect it or act as a shield. I understand LCDs give of interference, but many cars now come with LCDs or have them added later and they don't cause these problems so there has to be a solution.
Here is OSD's response to me email:
I appreciate your diligence in determining the cause of the interference you
are experiencing though there is nothing that OSD can do to support your
issue. We offer no drop in replacement part for this display and the part
has been discontinued for a few years now.
This is solely a discussion you need to have with Diablo Sport.
