Page 4 of 5
RE: Re: RE: Re: 2007 Dodge Ram - updated and now what!?
Posted: Mon Jan 09, 2012 3:14 pm
Its going to need to be reset...or let it finish the cal update on the vehicle it failed on.
Usually a turbo timer is responsible for tis type of issue...
Posted: Mon Jan 09, 2012 9:14 pm
by nemiro
Unfortunately, the vehicle is gone. What is entailed with a reset?
Posted: Wed Jan 11, 2012 11:09 am
by nemiro
*bump*
Posted: Wed Jan 11, 2012 11:44 am
call us with the tool powered up...
Posted: Thu Jan 12, 2012 11:15 am
by nemiro
OK, will do today.
Posted: Thu Jan 12, 2012 1:07 pm
by nemiro
Looks like tech support got me fixed up! Thank you all for your help!
Posted: Sun Jan 22, 2012 7:10 pm
by Daytona1445
How long should it take for the DCX update to install on to my 05 Ram?
Even with a good battery is a low amp battery charger a good idea?
Posted: Mon Jan 23, 2012 11:30 am
battery charger wont hurt ;)
Posted: Tue Jan 31, 2012 9:39 pm
by Ej205at30PSi
03PTGT my problem is the same as everyone. I have updated to 9r22 and still get "Predator does not support this vehicle call 561-bla bla> my CALid is 04510056ad. I thought i did everything i needed to do, but FAIL everytime. HELP.
im on the stage 1 pcm and 5 speed
Posted: Wed Feb 01, 2012 12:16 pm
Hmm...we support the 055AD cal, but not 056. Not sure why, but i have no way to add stage cals at this point, any chance someone can change the calid inthe ECU?
Posted: Wed Feb 01, 2012 1:04 pm
by Ej205at30PSi
So should I put in the stock ecu? Will that work.
Posted: Wed Feb 01, 2012 1:05 pm
more likely, yes.
Posted: Wed Feb 01, 2012 1:39 pm
by Ej205at30PSi
so stock ecu, with bigger injectors and the 93 tune, ill be able to start tunning away then? i dont have to rescale the injectors or anything? they are the ones that come with stage 1. Hope it works, or i have a $350 paper weight lol. Thanks.
Karma is what it is, my wrx dosnt like me driving the gt.
Posted: Wed Feb 01, 2012 3:25 pm
ideally you'll need an injector rescale.
Posted: Tue Feb 07, 2012 11:55 am
by Ej205at30PSi
Old ECU worked, updated worked, tune went in. BUT. I only see 14psi that tappers down to 10psi...thats way low for the 93 tune, no? should be 18 or so i thought?
