Page 4 of 8
Re: RE: Re: New Tunes
Posted: Sun Nov 14, 2010 5:27 pm
by 1camaro2SS
06MonteSS wrote:yes, the update will make a difference for your auto...
and a custom tune for it would make an even bigger difference...
Ok, just finished the update and programmed it into the car. I must say there is a difference in the shifting. Im not sure if it is the colder weather or the update is that noticeable but I actually chirped the tires a little shifting into 2nd gear which hasn't happened before. I will need to drive it for a week to really see the difference.
I plan on throwing some headers, a cam and CAi in the spring which at that point I will get a custom tune on the dyno. In the meantime this cant hurt.
RE: Re: RE: Re: New Tunes
Posted: Sun Nov 14, 2010 5:33 pm
yes, that change is from the new tune... that shifting is exactly what the update does...
enjoy!
Posted: Sun Nov 14, 2010 7:26 pm
by 1camaro2SS
How can I get that custom tune you mentioned earlier? I plan to install the Kooks 1 7/8 long tube headers with high flow cats and Cold air intake. Can I get a tune for these mods or do you recommend having it done on the dyno by a performance shop?
Posted: Sun Nov 14, 2010 7:39 pm
I can do that for ya...
sending you an email....
RE: Re: New Tunes
Posted: Mon Dec 06, 2010 2:58 am
by smrpilot
I have a U7194, and loved it in my '08 5.3 2wd. I just traded my '08 in for an'11 5.3 with 4wd and 6spd. Your site doesn't show anything for '11 Chevy yet. I plugged in my programmer tonight and it says incompatable vehicle. Are there any updates that I need to make this work? I've misplaced my box over the last years and have never plugged the programmer into my computer and don't even remember if i had a cable to plug it in. I also have v.9r01 on the predator. Do you have any suggestions? Thanks!
RE: Re: New Tunes
Posted: Mon Dec 06, 2010 11:42 am
2011 Truck support is available only in the Trinity currently.
Custom tune Have Volant CAI and Corsa sport cat back
Posted: Wed Dec 08, 2010 4:34 pm
by NeilStatler
Predator #u7194, v.9r18, 2010 GMC Sierra crew cab 2wd 5.3 flex.
I have a volant powercore CAI and a Corsa sport 3" cat back exhaust, i have been running the 91 tune but i just added these a few days ago. my question is do i need a modified tune due to the other aftermarket upgrades? And also i read somewhere about adjusting the flex mode to come on at a certain speed or throttle, it seems to only work at stop lights or when i start to stop.I tried cruise control at different speeds and just doesn't seem to wanna work. My rig is getting horrible gas millage right now, 14-15 mpg?
RE: Custom tune Have Volant CAI and Corsa sport cat back
Posted: Tue Dec 28, 2010 7:57 am
by 2010gmc
newbie question ive had tuner for a week just used adapter to plug it into wall ,it has the latest update in it do i have to marry it to the vehicle first before loading this update in it ?
2010 gmc 5.3 u7194 v.9r18
Re: RE: Custom tune Have Volant CAI and Corsa sport cat back
Posted: Tue Dec 28, 2010 11:09 am
2010gmc wrote:newbie question ive had tuner for a week just used adapter to plug it into wall ,it has the latest update in it do i have to marry it to the vehicle first before loading this update in it ?
you already have the 9r18 revision on yours... no need to update.. you already have the new tunes on there... the 9t18c that's mentioned in this thread, is the test/beta revision update before it was "Released" as 9r18... so, you already have it...
and no... whenever you do a revision update to the tool, it can not be married/locked to your vehicle... you have to restore original backup to the vehicle first, and then do the revision update...
RE: Re: RE: Custom tune Have Volant CAI and Corsa sport cat
Posted: Tue Dec 28, 2010 7:57 pm
by 2010gmc
thank you monte ,one more quiky if i could ,i read you have to pull the fuse for onstar when loading or unloading is this correct?
Posted: Tue Dec 28, 2010 8:14 pm
nah, don't have to really...
but, if you have ANYTHING aftermarket, you DO have to pull the fuse for those items... i.e. stereo, amps, subs, alarm, remote start, trailer brake, etc etc... if there is anything aftermarket installed, disconnect it...
Posted: Tue Dec 28, 2010 10:35 pm
by 2010gmc
thanks
Posted: Thu Feb 17, 2011 6:13 am
by 2010gmc
One more question monte will I get the improved shift with the 87 tune or just the diablo tune with 91-93,cause i really do want to spend less at the pump. thanks
Posted: Thu Feb 17, 2011 10:49 am
yes, the 87 tune should have those adjustments made it in already as well...
Posted: Thu Feb 17, 2011 6:38 pm
by 2010gmc
Just programmed truck with 87 tune and i really like the way it feels ,now it pulls harder and spins the tires everytime into second gear, I have not put on the cai from volant yet .I cant wait to do that then try the diablo tune with some 93 in it
