U7136 Updates
bighatch
Post by bighatch »
I got the new DSdownloader (2.1.0.4)
I got the new crom file v9r03 and installed it to my predator
Now I still cannot connect to the server to do the calibration update....
I get "The server reported an unknown error. Please try again later or contact DiabloSport support."
08V6CHARGER
Post by 08V6CHARGER »
try loading ds downloader and clicking on "express tune" on the bottom middle tab. then - "send crom file to tool". should work
bighatch
Post by bighatch »
08V6CHARGER wrote:try loading ds downloader and clicking on "express tune" on the bottom middle tab. then - "send crom file to tool". should work
I already installed the new crom file to my predator. I still can't do the calibration update that the DSdownloader says is needed...
rodhicks
Post by rodhicks »
Has anyone got this to work yet?
08V6CHARGER
yea mine is working in my car with no problem. try calling tech support bighatch cause i am at a loss. may be a defective unit
brlntblackse
Post by brlntblackse »
Are you behind a router or direct connection to your modem?
Have you turned off the windows firewall and and other software firewalls and antivirus software
bighatch
Post by bighatch »
brlntblackse wrote:Are you behind a router or direct connection to your modem?
I'm behind a router and I have antivirus and firewall disabled...
I have downloaded and installed the new DSdownloader program, also the new crom file and uploaded that to the predator but DSdownloader says I need a calibration update and that won't work.... "server error"???
brlntblackse
my guess would be your router is blocking you. If possible plug directly into your modem and bypass the router. If thats not possible maybe you can enable DMZ on your router temporarily which will make it wide open. Im not sure what ports you may or may not need to forward to use the DS DOWNLOADER or I would sya do that so you can use it at any time
brlntblackse
what cal id is your car showing
bighatch
Post by bighatch »
brlntblackse wrote:what cal id is your car showing
Calid is 05187031AE
I have plugged in directly to the modem and no luck :(
bighatch
Post by bighatch »
OK, this is weird....
For the hell of it, I plugged the predator into my car and everything fired up and it worked! I loaded the "Perf91oct" tune.
Then when I plugged it back into the PC and ran the DSdownloader, connected the predator, the calibration update was not required anymore???
So I think I'm OK now???
I just have to go and get the 91 oct gas first thing tomorrow...
brlntblackse
yup youre fine now
johan
Post by johan »
Would like to thank the guys who reported us to the BBB in regards to this matter, kudos.......
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
wow, for real??!!
what a Image
why don't you report microsoft too, for updates to fix shit-vista and other software for taking so long... or any other manufacturer for that matter... wow...
daaaamn...
bob34787
Post by bob34787 »
that should really bump the next round of v6 updates right to the top of the list!
