U7130 Extreme RKL 200hp & Perf Stacker tunes Downloads
ozpall
Post by ozpall »
Blacksmokecummins wrote:i put in a canned tune and then tried and all it says is that the custom tune does not match my truck and i tried with all the 15xxxx calids so what now
I'm getting the same deal, i uploaded the new software into my predator, v9r04 with 05xxxxAJ and when i try to put a tune to the truck says that it doesn't match with my truck, the one on the unit is AI and mine is AJ or something like that. i currently am running on the xtreme.
so what now???
'03 Black Quad Cab Dually 3500, 4x4, 6sp
Predator on xtreme, Air-Raid intake, MBRP 4" Turbo Back Exhaust, boost fooler, srt-10 hood.
Toys...
1 ton tacoma
Guys, if you look around, you'll see I have posted this answer several times, inthis thread even....
You have to install a tune fromthe Predator to the truck before you can load the customtunes to the predator, so do that first, then load the custom tunes, all set.
ozpall
Post by ozpall »
Mike, i had the extreme installed when i tried to load up the other one and i still get the same error that the calids don't match.
what are we doing wrong?
Toys...
1 ton tacoma
Wait a minute...so you updated without restoring the stock tune to the truck?
ozpall
Post by ozpall »
no i had it restore first
Toys...
1 ton tacoma
lap_traffic
Post by lap_traffic »
I had the same problem. Then I downloaded the latest version 9r-04 then I put in extreme tune, then the RKL extreme tune. This worked for me.
03 Dodge 2500 4x4, diablosport predator/puck, 2nd gen intake, airaid filter box, 6" GR stacks, leveled,
Voice_of_Reason
Post by Voice_of_Reason »
Could you give details of each tune? I'm confused as to what tunes do what, and have a bizarre thirst for information.
Thanks!
blackmagic1
Post by blackmagic1 »
i cannot install the custom tune puff stack!(my U7130 has last upadte 9r05)
my ID calib is 25325353 ag and custom puff stacker tune ID cali is 25325333AG
i take the puff stack tune 25xxxxx
and cannot install
what is the issue?
do you have a tune in the trukc now?
blackmagic1
No ,only have back up orignal!!
need to install a tune first...
blackmagic1
thank you for great info!
2500beast
tunes
Post by 2500beast »
i have the u7130 with the post re28. i downloaded the puff tunes what does each one do for the truck. my truck is not stock the trans has been built for 1000 hp and 1500lbs of torque. it has a industrial diesel silver bullet turbo, modified cp3, five inch exhaust and cold air induction. i love the black smoke and quick throttle response on the regular extreme but i have not used the new downloads. my 7130 was the 12xxx. i wont the truck to boil tires and take off like a bullet and handle offroad as well. explain what each puff tune is. thanks jack.
AdamRRT
RE: tunes
Post by AdamRRT »
So can I put the 7130 tunes on my 7131?
06 Mega Cab - HTS auto trans, Edge J/A gauges, Smarty TNT/Predator, Xzillaraider rail pressure gauge.
08 Charger - Predator
RRAM
RE: tunes
Post by RRAM »
I am pretty sure that is a negative
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
