U7194 update, again...
johan
Post by johan »
jjdeere9620 wrote:Well I downloaded rev 08 into my 7194 then connected to my pickup and it stored my original backup fine and installed the 87 octane program and the truck was running great. Then my battery started going dead. So I installed the original program back in and it killed my truck!!! It said to service engine, service stabiltrak, service 4-wheel drive and so on and was stuck in third gear. I'm not 100% sure that the revision had any thing to do with it but I thought I should let you know. If you have any input it would be greatly appreciated. thanks
09 Chevy Sliverado LT 4X4 5.3L 6 speed auto "M" series engine
Are you sure there isnt something going on with your battery, it is never ever a good idea to attempt programming while the battery is low.
Have you tried putting a charger on it and see if the predator recovers?
Please let us know and it is probably a good idea to call our tech guys.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
johan
Post by johan »
To everyone else, i am glad we are getting this sorted out for you.
The quicker we get these little bugs out of it the sooner we will continue on TCM for you guys :)
Diablosport INC
johan
Re: Error code (-14,-15)
Post by johan »
rjaro7 wrote:2007 2500hd nbs cal id 12622161
Have you tried the new update and let it take a backup, you will need to let it do that and then send me the file so we can add it in for you.
Diablosport INC
johan wrote:To everyone else, i am glad we are getting this sorted out for you.
WOOOHOOOOO!!!!!!!!
rjaro7
Post by rjaro7 »
im trying the tune now.... two things though.. how do i send you the backup and what do you mean by adding it in for me?
2010 GMC Sierra 5.3 Flex
johan
Post by johan »
rjaro7 wrote:im trying the tune now.... two things though.. how do i send you the backup and what do you mean by adding it in for me?
You export your backup using dsdl and then attach that file in an e-mail and send it to me and i will use that file to add support for your specific vehicle.
Diablosport INC
rjaro7
Post by rjaro7 »
Worked great...stored backup and tune is installed
kfc
Post by kfc »
Just installed the new update and everything works good so far, no problems.
johan ROCKS!!!!!!!!
2008 Silverado 4.8L
Predator U7194 v.9t23a
Tyan/AMD Opteron 144 @1.81 GHz.
WinXP SP3
johan
Post by johan »
LOL, working on adding some more guys plus i changed the spark and fuel adjustments so you will be able to adjust them specifically before, at and after peak torque, i also changed the spark adjustment from % to actual degrees, should have it done late today or tomorrow.
And i would also like to mention to you that without my helpful friend Alejandro here none of this would be able to be implemented.
Diablosport INC
excellent!!
Thanks Alex!!!!! YOU rock!!!!
then on to the TCM!!!
woohoo!!!!
Firedog
Post by Firedog »
Thanks Johan a bunch. I will be waiting and looking.
rjaro7
RE: Thanks
Post by rjaro7 »
oh hell yea johan and alex!!!!!!!
johan
RE: Thanks
Post by johan »
New one, with the 07 K motor added as well as:
Fuel adjustment rpm ranges changed to:
2k-3.8k
4k-4.9k
5k-7k
Spark adjustment rpm ranges changed to:
1k-3.8k
4k-5k
5.2k-7k
Reason for this change is so that you will have an adjustment at peak torque 4k-5k.
I also changed the spark adjustment to degree adjustment so you have a range of +/-10 degrees.
There was some datallog and dtc issues that where cleaned up as well.
http://www.diablosport.com/downloads/pr ... 9t08q.crom
Enjoy.
Diablosport INC
Firedog
RE: Thanks
Post by Firedog »
Thanks I will try it rightaway.
Firedog
RE: Thanks
Post by Firedog »
Johan I installed the 9t08Q crom into the U7194 and it Works great. It backup the orignal tune ok. I installed the 93 octane tune and will do some logging.
