Page 5 of 6
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE:
Posted: Thu Aug 19, 2010 10:08 pm
by Kahler
Mr. Trinity never killed my battery, ever. I never read these threads for it didnt kill mine. Now Im reading.
This week alone Mr.Trinity killed my batt twice this week and twice last week. Why all the sudden ? it drains.
I now just unplug it. Sure to wear out the connector soon. Is this new download a sure fix ?
Posted: Fri Aug 20, 2010 9:40 am
Yes, sure fix when you follow the instructions I posted.
(PS, your car knows what you are reading, lol)
Posted: Fri Aug 20, 2010 10:13 pm
by Kahler
lol lol I think the bi!ch does... damn her.
oK ill give it a try see what happens. Thanks Mikel
Posted: Tue Aug 24, 2010 2:29 pm
by HEMISFEAR
I hope this fixes my key fob not working all the time thing. It only started after I plugged in my Trinity and currently only works when I'm right up to the car. I have another key fob that I've never used since purchasing the car and the same thing occurs. If I unplug my Trinity, both work again and flawlessly. Weird.
Posted: Fri Aug 27, 2010 1:25 am
by Maxximuss
Just wanting an update to anyone who has left their trinity plugged in......did the new fix work? I have the update but haven't risked leaving it in the car hooked up. I rather wait to hear that this is fixed first.
Posted: Sun Aug 29, 2010 4:33 am
by TIGwelder
Mike,
Does this also fix the battery drain problem with 2008 SRT-8 Chargers?
I know the discussion started to focus on the newer Challengers at some point.
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re:
Posted: Mon Aug 30, 2010 10:20 am
TIGwelder wrote:Mike,
We have not seen 08 Chargers to be an issue, but it should work just the same if you had a problem.
Posted: Mon Aug 30, 2010 1:12 pm
by TIGwelder
mikel wrote:We have not seen 08 Chargers to be an issue, but it should work just the same if you had a problem.
Mike..no disrespect man. I realize there's 234342 threads to cover and your a busy man....but if I had the facepalm image..
<it would be right here>
TIGwelder
Post subject: Auto shutoff - "Possibly" Killing Battery
Posted: Dec 18, 2009
http://www.diablosport.com/index.php?na ... ic&t=19679
Is it the same update file? I'll give it a go
Posted: Mon Aug 30, 2010 2:22 pm
I do recall that thread.
When I say we have not seen that to be an issue, I mean, out of 1000s of Trinitys sold, I have only seen that in the 2 vehicles listed there, and as mentioned, the other vehicle had similar issues with the Dashhawk, which 1000s of other people do not have problems with either.....see where I am going with this ?
Try the update, change the sleep time to 30 seconds, and let us know.
Posted: Mon Aug 30, 2010 5:26 pm
by TIGwelder
Ok. I wrote down my current adjustments to stock tune just in case(fan, etc)
Restored my original backup to the car.
Used the downloader and it updated the tool. It loaded the entire update to the tool. I think I saw every vehicle known to man load on there..lol
Set vehicle type and sat confused in car looking for new setting under options>
Then after rechecking the thread I realized the incremental is in this thread, not on the updates page, so I added trinity_u7135-1t07ca and updated
Then it said it wasn't married to vehicle.
Modified stock tune and it saved original backup, modified stock tune then loaded in car.
I'm I correct to this point? I think I goofed by installing original backup when I started...but I was paranoid
I then found the new setting and set it at 30 seconds
I started the car. Put the Trinity in monitoring mode. Shut off car and noticed the delay at the "halt monitoring" screen seemed much longer. A good sign..I'm seeing something different..update applied correctly
After key off I listened and heard the sub heartbeat a few times while the CAN bus settled a bit. Then heard nothing.
I'll leave it overnight and report what I find.
Thanks Mike.
Posted: Thu Sep 09, 2010 10:08 pm
by Maxximuss
I await to hear TIGwelder, crossing my fingers. Let us know.
Fixed the battery drain but note this
Posted: Sat Sep 11, 2010 1:44 pm
by waumo
I installed the update and the Trinity and car equipment does now shut off and the battery drain drops from 4 amps (4000 mA) down to about 150mA.
Without the Trinity attached the normal parasitic battery drain is about 20-30mA.
So the update did solve the problem of the battery draining overnight.
I still would not want to leave the car setting with the Trinity connected for more than a week or so at most.
RE: Fixed the battery drain but note this
Posted: Wed Sep 22, 2010 10:43 pm
by Maxximuss
Thank you for the update waumo, I think I'll stick to not leaving mine in the car unless I plan on doing some playing. I just don't like the idea of leaving it in the car and still not satisfied about the draining of the battery possibility.
Posted: Sat Oct 02, 2010 4:55 pm
by SRTorRed6sp
waumo, I have left my Trinity hooked up for a week and it will indeed kill the battery. Disconnect it and I can let the car sit a week with no problem. So you are correct. Sitting a week may kill your battery with it hooked up.
Re: RE: Fixed the battery drain but note this
Posted: Mon Oct 04, 2010 10:25 am
SRTorRed6sp wrote:waumo, I have left my Trinity hooked up for a week and it will indeed kill the battery. Disconnect it and I can let the car sit a week with no problem. So you are correct. Sitting a week may kill your battery with it hooked up.
Even with this new fix, you have a problem?
