Page 5 of 5
RE: Re: RE: Re: 2007 Dodge Ram - updated and now what!?
Posted: Tue Feb 07, 2012 12:43 pm
try raising the boost a bit...also check for boost leaks.
Posted: Tue Feb 07, 2012 4:42 pm
by Ej205at30PSi
no boost leaks. so i read that i might again have a pcm with the torq limiter turned on or something? if so how to shut this off, so i can get to normal boost. i did thought it made it slower then the stage 1 pcm
this is stage 0 pcm with stage 1 injectors on 93 tune.
exhaust/3 dp NO CATS. 3inch intake from turbo to stock air box.
stock IC pipes for now
Posted: Wed Feb 08, 2012 12:46 pm
by Ej205at30PSi
anyone? anyone? buller ?buller?
Posted: Wed Feb 08, 2012 2:05 pm
Might help to start a new thread with the appropriate topic 'title' so we can help.
You are posting in a sticky thread that does not get checked regularly...
I'd actually start a thread here:
http://www.srtforums.com/forums/f384/
You won't find a more informed group of SRT4 guys anywhere.
Posted: Sat Mar 03, 2012 3:24 am
by hwy97
I'm fighting with my '07 Hemi and a new install of a 7137. I get the normal "needs an update" but at step 3 of the download into the tool about half way through a pop up "update completed wait for tool to reboot" but nothing else happens. The 7137 goes into the menu with performance tune at the top. When I try to go forward I still get the "needs to update". The update is Calid 05094402ag. I'm using the pl2303prolific driver installer and the latest update off the site. ?????
Posted: Sat Mar 03, 2012 4:44 pm
by hwy97
figured out on my own....
Posted: Tue Apr 17, 2012 9:18 am
by mrmrvos
I hooked up my Diablosport u7137 and it states "vehicle needs update, tool is married to another vehicle." Did i buy a used tuner because where i bought the tuner it said it was new? My computer runs Windows 7 and this is getting to be very confusing.
Re: "This Vehicle Needs an Update Download Here.."
Posted: Wed Aug 29, 2012 7:40 pm
by abdallah79
Hi there, A jeep commander is giving the following message:
"Predator u7137 does not support calid 68059192AA"
Guide me please
thanks alot
SA
Mohamed
Posted: Wed Aug 29, 2012 7:50 pm
by Mike_Levy
This is an export truck? I don't think exports are covered by the u7137. Mike will have to confirm.
Posted: Fri Oct 19, 2012 10:01 pm
by stvsherrod
Recently got my truck back from the shop. They changed the PCM and an ignition module. I tried to put the predator tune back into my truck and it says..
"Your calibration is 6805944AD an it is nt supported. We need to downgrade to 6805944AB.... ect." I press agree and it says
"This vehicle needs an update. Download here: diablosport.comdcx Calid:6805944AB
What exactly do I need to download? When I boot it up it says it has v.9r13. I just updated everything May 21st so I thought I should have the current stuff. I think last time someone had to email me v9.09 for something but I don't really remember. I still have that in a folder. Do I need to do something with it first? I do remember back in May when I was trying to update everything it was kind of a pain... Please help.. Thanx in advance... Steve
Posted: Tue Mar 25, 2014 10:10 pm
by nfs hemi
have u7135 how do i marry again after i installed new firmware ? need help tnks ...
Posted: Wed Oct 12, 2016 8:10 pm
by Marianov21
i need an update for my predator U7135 ......i have a 2008 dodge ram 1500 5.7 hemi ....i bearly saw this post ,because im new here but yea im looking for an update for my predator.
Posted: Thu Apr 20, 2017 3:16 pm
by azle
Added all the downloads tuner said down load complete. tried to put the tune in my 05 5.7 magnum with the U7135. wont load tune reads: PCM:bootup string missing/VPP issues.
Please advise
Azle
Posted: Wed May 10, 2017 5:52 pm
by dc0ntreras
I took my 09 Challenger in for airbag replacement and oil change. The dealership updated my PCM software now my tune is not working. The predator has the error stating that the PCM flash is not compatible it was updated to AH and it needs to be AD. The dealership says they cant downgrade ....is this correct???
What the hell, now I cant use my tuner and it has a cam so it does not idle very good. it turns off at idle sometimes now. Do I have to buy another tuner?
