Page 5 of 14
Posted: Thu Oct 20, 2011 4:46 pm
11z71 wrote:Well, i downloaded the crom you sent me mike, everything looked good, diablo tranny tunes finally came up in menu, went to install my tunes, backed up originals for both pcm and tcm, the trinity proceded to install pcm tune, then tranny tune, no sooner did the counter start for flash for tranny tune the trinity locked up for whatever reason, then it said in the display that last tune did not finish. the original will be restored, hit ok, restore original back up now? select yes, Tells me unable to restore original backup,select more info and comes up with tcm= error write failed(-18). This is all that it does now when i plug it in, it repeats the same menu's regardless of how long i leave it unplugged, I can't tell whats in the truck for software now, it runs and drives fine, but my trinity is locked now.
got it sorted out, ran into the exact same issue here on the boss' 2011 CTSV, I am emailing you the update now.
You'll need to call from the PC so we can force the update on since the tool is locked.
Once the update is on, it will allow you to restore in recovery mode, then you can tune away
Posted: Thu Oct 20, 2011 4:47 pm
48548 wrote:As soon as your are ready for another 2011 test, let me know. Ordered the trinity yesterday and it will be here tomorrow. I can test on the 2008 g8, but really want this for the 2011 ext. I am ready to fix that sloppy cadi shifting and make it more like my 4l60e with a transgo hd2.
fixed
Posted: Thu Oct 20, 2011 4:51 pm
by 48548
Perfect got it, now I will test and let you know how it is working. Thanks for the quick reply. I hoping to really enjoy the better shifting.
Posted: Thu Oct 20, 2011 4:57 pm
by 11z71
Hey mike thanks for figuring that out, here's my issue though, yesterday at work I blew my knee out so I am gonna be out for a while until we figure out what's up with it. All my stuff is on my work computer. I'll get back with you when I'm back. When that is though I don't know. Thanks for your efforts.
Posted: Thu Oct 20, 2011 5:16 pm
Ouch, get better man!
Posted: Thu Oct 20, 2011 8:55 pm
by Xtremelylow
Hey man I have 2008 Yukon Denali can you please email me the new file
Thanks Rob
Posted: Thu Oct 20, 2011 9:41 pm
by JohnHarrison1
Can you sent me a copy for my 2010 camaro ss. Email address is
Posted: Fri Oct 21, 2011 8:57 am
sent to both of you
Posted: Fri Oct 21, 2011 3:34 pm
by Bulls729
Mike,
When its ready I'll happily make my vehicle available for T42 development
I can do double testing if you know what I mean
Posted: Sat Oct 22, 2011 10:04 pm
by 48548
Alrighty... I did some testing and while it worked I noticed some bugs... Thought I would post them up to help out get them worked out. It would appear I had an error trying to go from econo mode programing to 87 tuning, because it would appear econo mode didn't backup the TCM... Then I got odd errors about cal not supported but only once... So I went was able to restore backup and then went from 87 to econ and that appeared to work better and tranny was shifting nice at WOT, but needed some more help at normal driving. Then I got home and wanted to go back to stock and it said pcm error -1 but I tried it again and it worked. So it just seems like I have to try a few times for some reason, also I unnderstand this is still beta testing... The question I wonder is, I like the g8 shifting in sport mode that we have, can I copy those stock settings over to the ext? Or does the EXT shift different because it is 2000 pounds more and AWD? Good work and I can't wait for the completed code to be released. Also can't wait for TCM to work with ECO mode tunes as well. Also I can do more testing if you want me to try specific things as well. This was on my 2011 escalade ext, with 6.2 and 6l80e.
Posted: Mon Oct 24, 2011 10:02 am
It sounds like your tcm was not supported.
Did it actually let you select a tune, or just the 'modify stock tune'.
Posted: Mon Oct 24, 2011 11:30 am
by 48548
Yes it did, it let me pick the 87 tune and it did back up the PCM and then the TCM. Let me know if you want me to upload my TCM so you can confirm it was supported.
Posted: Mon Oct 24, 2011 11:44 am
please do, still does not sound like you selected a TCM tune, they are not listed by octane
Posted: Mon Oct 24, 2011 11:55 am
by 48548
How do I do that? Also it won't be until friday as I dropped the car off to get scratches fixed and a window seal replaced.
Posted: Mon Oct 24, 2011 11:59 am
just export the backups with the DSDownloader.
