MEXICO AND DIABLOSPORT.....will it work?
johnc
Post by johnc »
alssiri wrote:Still geting same update message & no caliberation update button is appearing on the downloader.
Calid 05030234AD
I just checked, your update is up there. Assuming you have the latest CROM revistion, try this:
  1. Close DS Downloader.
  2. Open the following link: http://www.diablosport.com/index.php?na ... pic&t=3622
  3. Follow the instructions under Q5 to change the COM port assigned to your usb-to-serial cable.
  4. Change the COM port to a lower number, like 6.
  5. Restart DS Downloader.
johnc <at> diablosport.com
smoke74
Re: RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABLOSPORT.....w
Post by smoke74 »
johnc wrote:The "Performance Tune" is 93 octane. In the r17 revision Johan changed the name to perf93 to avoid confusion.
yeah the 93 tune is there indeed but the 91 tune is not :shock:
smoke74
RE: Re: RE: Re: RE: Re: RE: Re: RE: MEXICO AND DIABLOSPORT..
Post by smoke74 »
btw im getting 0.00degrees knk retard both lt and st so is it ok to use 92 octane?
06 Charger RT
alssiri
Post by alssiri »
Calid 05030234AD
JOHN
Thaaaaanks man,it was the com port that was giving me all the truble.
Thanks :D :D :D :D :D :D
Ahmad
Jareza
Post by Jareza »
I just dont see where the 91oct tune is.... could someone explain to me why was it deleted?
thanks!
Tyrant
Post by Tyrant »
Johan at lx forums said it was due to size restriction (memory size i assume)
but he said it should be fine to run on 91 oct by retarding timing down by 3 degrees, .. (anyone at diablo please chime in and correct me if i'm wrong)
anyways still waiting on a fix for my cal id
smoke74
Post by smoke74 »
what PIDS should i be looking, to see if running 92 octane gas is working with my car?
edit:
im in my car with my laptop and i see knk total retard and knk max total retard.
knk total retard stays at 0.0 all the time except when i shift it goes to -2 then back to 0 all the time.
knk max total retard during wot is goin from 15 down to 7 at shift
as for spark its moving with the rpms but i dont know what i should be looking for, damn i dont even know if this info is even of some use
i did this with ESP enabled, can this affect the results as it's preventing my tires from spinning?
coliseum
Post by coliseum »
Dudes? where's my fix? well... another day wasted :( :?
alssiri
Post by alssiri »
coliseum wrote:Dudes? where's my fix? well... another day wasted :( :?
It's on the site & just follow Johnc steps & you'll be fine :D
Ahmad
Tyrant
Post by Tyrant »
^^ still doesnt work for us bro... i did everything mentioned by John but still ti didnt work :(.. me and Colisem will have to wait and see what happens now.
coliseum
Post by coliseum »
Alsirri... is your car from the USA or Gulf Specs (export)?
alssiri
Post by alssiri »
coliseum wrote:Alsirri... is your car from the USA or Gulf Specs (export)?
GCC specs.I downloaded the new CROM & still got the vehicle need an update message & couldnt get the calibration updater button then i followed Johnc steps & changed the COM PORT & voala :) i got the calibration updater button & got it updated.
Ahmad
coliseum
Post by coliseum »
Did u get a message your CAL ID is not handled? or where you getting a communication error when you tried the Calibration update? Because mine seems to be able to connect to Diablosport Database, however the CALID I have is not supported which is what I am waiting for...
alssiri
Post by alssiri »
coliseum wrote:Did u get a message your CAL ID is not handled? or where you getting a communication error when you tried the Calibration update? Because mine seems to be able to connect to Diablosport Database, however the CALID I have is not supported which is what I am waiting for...
The only messag i got was Vihicle needs update on the tool.
Ahmad
coliseum
Post by coliseum »
and what used to happen when u plugged the tool to ur laptop? did u get a message that your CALID is not supported OR that you cannot reach the site?
