2011 Dodge ram shifting issues...when's the fix coming?
Javier_Wilde
Re: 2011 Dodge ram shifting issues...when's the fix coming?
Nothing yet?...
They are still working on it lmao. Go figure it's ONLY been over 8 months well aleast i can use the lemon tuner on my ls2 cts-v
bump......................................
2011 Ram RT. vararam intake, ARH 1 7/8, Corsa exhaust, Diablo Catch Can, Arrington 85mm TB, V6 fan install, Edge 3400 convterter. Trinity CMR by Duster360 & Whitelighting.
Glad i'm not the only one getting ignored.
we are looking into this and see that it was already fixed for the only calid that was reported here.
Anyone having this issue currently please post your calid (options/troubleshooting/show info)
So has the issue been resolved? What RPM is this person shifting at?
How come we weren't told about it or an update for the tuner?
there was an update done right after this was reported to fix the reported calid.
If you guys have a different calid, we need to know so we can fix that as well.
I see some saying the 1-2 adjust lead to bouncing off the limiter...that indicates that the shift point was raised, and you need to raise the rev limiter to get there
White lightning does my trans tuning and on a commanded 6000 rom shift at the highest it shifts at is 5884rpm? Do I need a updated calid?
post a copy of the last tune written from your tool please.marku wrote:White lightning does my trans tuning and on a commanded 6000 rom shift at the highest it shifts at is 5884rpm? Do I need a updated calid?
- white_lightning
marku's cal# is: 68059124AHmikel wrote:post a copy of the last tune written from your tool please.marku wrote:White lightning does my trans tuning and on a commanded 6000 rom shift at the highest it shifts at is 5884rpm? Do I need a updated calid?
do you need a tune file to fix the template?
FWIW, I have not been able to get any of the 11 or 12 Rams I have trans tuned to shift much higher than 5800. and I have seen several different cal#'s for each year.
shift tables and shift scalars look similar to 09 and 10, and those I can set to shift way above 5800.
I have successfully set WOT shifts as high as 6900 for a forged motor Ram.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
My Ride:
With 6k commanded shift, it now shifts at 5761rpm vs 5884 with it commanded to shift at 5800? This is the issue that seems like everyone else is having
- white_lightning
yes, that is what all the 11 and 12 Rams do when I set WOT shifts for 6000rpm. ALL calibration #'s.marku wrote:With 6k commanded shift, it now shifts at 5761rpm vs 5884 with it commanded to shift at 5800? This is the issue that seems like everyone else is having
My Ride:
My Ride:
