2012 wrangler update ?
Re: 2012 wrangler update ?
Emirates81 wrote:i got the custom tune maybe it has some issue then.
am asking about an update wich includes manual trans also
Thaks for your quick replies.
that should be out today or monday.
noise.boy
Post by noise.boy »
Still looking for a fix to NO Throttle response on 2012 JK manual trans. Help
noise.boy wrote:Still looking for a fix to NO Throttle response on 2012 JK manual trans. Help
I will gladly make you a custom tune, simply post up the backup or last tune written file please.
noise.boy
Post by noise.boy »
Ok, so I tried writing the 91 with no throttle response on a manual transmission. I then restored and no problem. Then tried 87 tune and no throttle response then restored original. When i try to get tune from tool it says it doesn't have original back up or last tune. A custom tune will be fine if that fixes the problen of no throttle response. However is that good for just the single tune? I can see several situations where changing tunes will be advantageous.
At the risk of sounding ignorant, how do I "post up" the last tune? Help
noise.boy wrote:Ok, so I tried writing the 91 with no throttle response on a manual transmission. I then restored and no problem. Then tried 87 tune and no throttle response then restored original. When i try to get tune from tool it says it doesn't have original back up or last tune. A custom tune will be fine if that fixes the problen of no throttle response. However is that good for just the single tune? I can see several situations where changing tunes will be advantageous.
let the tool read a copy of the backup, then connect it to a PC and export the backup file, then attach it here please.
noise.boy
Post by noise.boy »
Here is the original back-up:
PCM_68090873AG.drg
(91.11 KiB) Downloaded 216 times
noise.boy wrote:Here is the original back-up:
here you go.
pcm_68090873ag_perf.drg
(72.72 KiB) Downloaded 253 times
noise.boy
Post by noise.boy »
Thanks Mike. Will load it shortly.
noise.boy
Post by noise.boy »
fyi. Just a test run. Big performance difference! So far so good! Thanks
Last69
Post by Last69 »
Mikel, any update for 3.6 auto trans? I need some more performance. I didn't feel that power after using performance tune (test 91 & 93 oct)
Emirates81
Post by Emirates81 »
noise.boy wrote:fyi. Just a test run. Big performance difference! So far so good! Thanks
Can u tell me how did you know that you got a big performance Plz ?
Where do you stay ?
noise.boy
Post by noise.boy »
Where do you stay ?
Emirates81, I didn't use a dyno. Just took it out on the freeway here in TX. Local stretch has 75 & 80 mph speed limits. The big improvements are acceleration and torque with all my add ons. Bigger tires, bumpers etc.... Feels better than stock.
Emirates81
Any updates? It's Friday :D
update to fix the manual cals is here:
trinity_dcx_gas-1t09ha_update.crom
(2.89 MiB) Downloaded 263 times
Emirates81
Thanks :twisted:
