Page 5 of 7
Re: 2012 wrangler update ?
Posted: Thu Feb 14, 2013 11:14 am
Emirates81 wrote:i got the custom tune maybe it has some issue then.
am asking about an update wich includes manual trans also
Thaks for your quick replies.
that should be out today or monday.
Posted: Thu Feb 14, 2013 7:10 pm
by noise.boy
Still looking for a fix to NO Throttle response on 2012 JK manual trans. Help
Posted: Fri Feb 15, 2013 10:38 am
noise.boy wrote:Still looking for a fix to NO Throttle response on 2012 JK manual trans. Help
I will gladly make you a custom tune, simply post up the backup or last tune written file please.
Posted: Fri Feb 15, 2013 11:32 am
by noise.boy
Ok, so I tried writing the 91 with no throttle response on a manual transmission. I then restored and no problem. Then tried 87 tune and no throttle response then restored original. When i try to get tune from tool it says it doesn't have original back up or last tune. A custom tune will be fine if that fixes the problen of no throttle response. However is that good for just the single tune? I can see several situations where changing tunes will be advantageous.
At the risk of sounding ignorant, how do I "post up" the last tune? Help
Posted: Fri Feb 15, 2013 11:43 am
noise.boy wrote:Ok, so I tried writing the 91 with no throttle response on a manual transmission. I then restored and no problem. Then tried 87 tune and no throttle response then restored original. When i try to get tune from tool it says it doesn't have original back up or last tune. A custom tune will be fine if that fixes the problen of no throttle response. However is that good for just the single tune? I can see several situations where changing tunes will be advantageous.
let the tool read a copy of the backup, then connect it to a PC and export the backup file, then attach it here please.
Posted: Fri Feb 15, 2013 12:00 pm
by noise.boy
Here is the original back-up:
Posted: Fri Feb 15, 2013 2:58 pm
noise.boy wrote:Here is the original back-up:
here you go.
Posted: Fri Feb 15, 2013 3:03 pm
by noise.boy
Thanks Mike. Will load it shortly.
Posted: Fri Feb 15, 2013 3:49 pm
by noise.boy
fyi. Just a test run. Big performance difference! So far so good! Thanks
Posted: Sat Feb 16, 2013 3:02 pm
by Last69
Mikel, any update for 3.6 auto trans? I need some more performance. I didn't feel that power after using performance tune (test 91 & 93 oct)
Posted: Mon Feb 18, 2013 11:08 pm
by Emirates81
noise.boy wrote:fyi. Just a test run. Big performance difference! So far so good! Thanks
Can u tell me how did you know that you got a big performance Plz ?
Where do you stay ?
Posted: Tue Feb 19, 2013 3:14 am
by noise.boy
Where do you stay ?
Emirates81, I didn't use a dyno. Just took it out on the freeway here in TX. Local stretch has 75 & 80 mph speed limits. The big improvements are acceleration and torque with all my add ons. Bigger tires, bumpers etc.... Feels better than stock.
Posted: Fri Feb 22, 2013 4:08 am
by Emirates81
Any updates? It's Friday :D
Posted: Fri Feb 22, 2013 10:34 am
update to fix the manual cals is here:
Posted: Sat Feb 23, 2013 6:24 am
by Emirates81
Thanks :twisted:
