8 Speed Transmission
Lars
Re: 8 Speed Transmission
Post by Lars »
Hello,
I am not sure if the update running well. If i connect the i2 to my C7 it always says Unknown TCM found.
Can you check if everithing is correct, please.
Thank you
Best Regards
Lars
Zach
Post by Zach »
This is the most current tester database with your calibration supported.
Drag and drop it into the main directory of your I2 and let the tool update.
Lars
Post by Lars »
Hi,
I put the file in the main directory. But nothing happens?
I ran the updater and rebooted the device.
What can i do?
Zach
Post by Zach »
you do not need to run the updater.
Post your info.xml file please
Lars
Post by Lars »
Thank you Zach
Zach
Post by Zach »
Ok, you're tool is out of date.
Drag and drop the update i attached here on the forum onto the main directory of your tool and wait for the tool to start importing it.
It will show on screen that it has started to load the update. No need to run the updater.
Lars
Post by Lars »
The GM-Tune-xxx file?
Only drag & drop to the main Directory and wait? How Long?
Zach
Post by Zach »
The main directory of the I2, should only take a minute or so
Lars
Post by Lars »
i'm waiting and waiting .... but nothing happens.
is the file at the right place?
and i must only wait? No command to start the update?
Zach
Post by Zach »
delete the group update from the folder.
Lars
Post by Lars »
i deleted the file. But nothing happens.
any ideas?
delete the file..
unplug the intune..
wait about 10 seconds..
reconnect it to the computer...
Lars
Post by Lars »
I am sorry.
The device does no update.
Lars
Post by Lars »
I can do what I want. The device does no update.
Is there a possibility to reset the i2?
toneyjay
Post by toneyjay »
The update worked for me just as stated. copied to root dir of tune and few seconds later started updating. It recognized my trucks TCM and I tuned. And the difference is day and night. Tranny was just sloppy feeling before unless I drove it like a sports car and it felt okay. After the tune it feels crisp when cruising and even better when driving as a sports car. Very very happy. Now time to work on a Diablew custom tune. Thanks Diablo team.
