Page 6 of 7
Re: Few issues with E version Tune.. 2012 SRT Charger
Posted: Sun Dec 16, 2012 8:49 am
by dkoong
Yeah but all you have to do is enter the performance tune menu. You don't have to tune it. The voltage warning prevents you from going ahead
Posted: Sun Dec 16, 2012 9:07 am
by maherm
Tried the e version, it is true that I it was a great improvement on the 6.1....but can't feel the wow performance on the 6.4....hope they have a better tune with cai
Export 300 Srt 2012
Posted: Sun Dec 16, 2012 9:19 pm
by Piggy671
dkoong wrote: did you try without the battery charger connected?
Plugged it in without the batter charger this morning. No messages about voltage. Then I installed another tune also without charger. No issues.
Posted: Mon Dec 17, 2012 12:13 am
by dkoong
very happy for you
i am still too chicken to try.
im just skirting around the edges.... toe into the pool as it were.. LOL
:lol:
Posted: Mon Dec 17, 2012 12:31 am
by Piggy671
Yeah, fair enough. I understand after what you've been through. If I were you I wouldn't be doing it without a battery charger on at least.
Edit: And that's after making sure the battery is fully charged.
Posted: Mon Dec 17, 2012 7:16 am
by dkoong
i dont understand why i would be getting low voltages. car is new. been daily driven.
Posted: Mon Dec 17, 2012 9:00 am
by Bullish
Low voltage is one of the minor problems with the E tune I assume DS is working on it along with the -18 error. (See the first few post of this thread..) I posted it as a problem.. I just ran my car for about 10 min's then I was able to upload tune...
Question.. What is this battery connectors ya are talking about ?
Posted: Mon Dec 17, 2012 11:17 am
dkoong wrote:i dont understand why i would be getting low voltages. car is new. been daily driven.
if the trinity sees less than 12V when it starts a flash, it says no dice, it does not mean you have low voltage, just that it has less voltage than is ideal for flashing...
Posted: Mon Dec 17, 2012 7:20 pm
by dkoong
So connecting a charger will fix it?
Posted: Mon Dec 17, 2012 7:30 pm
if you get the error, yes, it should prompt you to connect a charger...
Posted: Thu Dec 20, 2012 1:03 pm
by Bullish
2nd Gen tunes will be made available for the InTune programmer in mid Jan..
I hope that a 100% working tune for the Trinity is available prior to that..
Posted: Fri Dec 21, 2012 8:35 pm
by mannytwotwo
It appears F is out...anybody try it yet? I won't be able to install it until Monday...
Posted: Sat Dec 22, 2012 9:13 pm
by Bullish
I will be on vacation till Jan 2nd..
So I will try it then.. However with the help of DS I was able to adjust my shift pts via quick adjust and was advise I could still adjust my throttle boost. I did both with the E and MAN O MAN.. Wow.. So I look forward to uploading the F so I can make my adjustments via the main menu instead of the quick menu and adjust other things as well.
Posted: Sun Dec 23, 2012 1:40 am
by mikesrt8superbee
Bullish wrote:I will be on vacation till Jan 2nd..
what exactly is the shift points and why would you want to change them? is it just a raised redline?
Posted: Sun Dec 23, 2012 9:41 pm
by mannytwotwo
"F" appears to be doing well. I finally have the option of calibrating the wheel size so I can dial in my 22s. I'm still not convinced MDS is actually turning off but I'll run some data logs this week just to be sure.
