Cannot register Intune
wgerickson
Re: Cannot register Intune
Post by wgerickson »
I think i went to the right website to register my Intune, what happens after that do i receive a file or something, i have tried updating the intune and says it cant till it is registered.
I bought it few years back and found out it will work with my truck i have. So want to use it for towing.
my email is [email protected]
thanks
Bill
mike_m
Post by mike_m »
wgerickson wrote:I think i went to the right website to register my Intune, what happens after that do i receive a file or something, i have tried updating the intune and says it cant till it is registered.
thanks
Bill
I have emailed you a request for your info file so I can complete the registration. Send it when you can, and I'll handle it for you.
deadcatsrule
Post by deadcatsrule »
I can not register my intune aswell
info.xml
(2.33 KiB) Downloaded 871 times
14SilveradoWidow
Post by 14SilveradoWidow »
I cannot register mine as well. One of a plethora of problems I'm having. Please help!
info.xml
(2.1 KiB) Downloaded 820 times
14SilveradoWidow wrote:I cannot register mine as well. One of a plethora of problems I'm having. Please help!
save this to the intune drive.
registration.itf
(377 Bytes) Downloaded 969 times
deadcatsrule wrote:I can not register my intune aswell
attached.
registration.itf
(377 Bytes) Downloaded 906 times
deadcatsrule
that worked,thanks
Bigmak
Post by Bigmak »
Can't get it to register.
info.xml
(1.67 KiB) Downloaded 889 times
Shaneous69
Post by Shaneous69 »
Just got my I2 yesterday and when I try to update it, I get
"unexpected error has occurred: Registration unable to locate file E:/info.xml
Object reference not set to an instance of an object"
Cheers,
Shane
brad2192
Post by brad2192 »
Greetings!
I just purchased an i1000 and updated it to the 1r04i firmware via the updater program. I have already registered my device but once I boot the updater after all of the updates have been completed I get a blank error message and then the registration page opens. I have tried numerous times with the same issue. I'd appreciate your help, thank you for your time!
-Brad
info.xml
(1.79 KiB) Downloaded 964 times
brad2192 wrote:Greetings!
-Brad
save this to the intune drive to register the device.
registration.itf
(377 Bytes) Downloaded 1025 times
bowhntrsd
Post by bowhntrsd »
I am unable to register and update.
info.xml
(2.05 KiB) Downloaded 885 times
brad2192
Post by brad2192 »
Still did not work, after it rebooted it somehow ended up deleting the Ford config files. It says missing in the firmware info and still will not let me update or manually update those files. I've been stuck for 3 days now.
brad2192
Post by brad2192 »
Still did not work, after it rebooted it somehow ended up deleting the Ford config files. It says missing in the firmware info and still will not let me update or manually update those files. I've been stuck for 4 days now.
I emailed you a new reg file to use.
