2012 wrangler update ?
vitodivita
Re: 2012 wrangler update ?
Hm. My MPG is stuck around 14-15. Not sure what is to blame for this? I have stock size suspension. Prior to the tuner I was getting 16. The last 2 tanks I have been driving conservatively and still can't get better fuel economy. I've been using 93 octane since it had zero miles on it, all shell fuel. I added a K&N filter a few weeks ago, I'm debating just taking that off.
I also turned on the "MDS" option, and I think it made it worse. This is on a 12' Unlimited with 13k miles.
The 3.6L doesn't have MDS.
Does the Trinity for the 2012 JK Wrangler 3.6L allow changes to shift points? Change when the locker can be used, like in 4H? Completely disable traction control? Are custom tunes available for this platform? Would just a CAI & exhaust benefit from a custom tune?
vitodivita
Well they put that option in the tuner.
No changes to shift points. No off-road options yet. Yes you can diable traction. Yes you can do custom tunes. and yes I'm sure.
Are there future plans to add shift point adjustment & diff lock while in high range?vitodivita wrote:Well they put that option in the tuner.
we plan to add a bunch of stuff here
Shift point adjustment & diff lock while in high range? Pleeeeeeaaaase....mikel wrote:we plan to add a bunch of stuff here
Do you recommend a custom tune for a CAI & exhaust?
vitodivita
Is it okay to use the mileage saver tune on 93 premium?
Emirates81
mikel wrote:update to fix the manual cals is here:
It worked fine in my Trinity .
What about intune dcx cause it didn't identify.
Any ETA for the additional adjustments: Spring, summer, fall...?Mopar2Ya2 wrote:Shift point adjustment & diff lock while in high range? Pleeeeeeaaaase....mikel wrote:we plan to add a bunch of stuff here![]()
2012 JKU RUBIKONG: Far too much to list here...
Emirates81
I am not happy with the tunner no power gain at all
I got my last week and on the 87 tune it's great. I'm waiting till I'm empty to fill it with 91 and try the performance tune. I wish Diablo would release or give a good timeline on the Rubicon tune options.
OK, I filled my tank with 91 and re-installed the tune to 91. At low speeds it seemed more sluggish than the 87 tune but at hire speeds you feel the pickup. I did about 450 mile freeway round trip on somewhat flat roads and after my return filled up the tank and calculated my mpg to 16.8. I took my tune back to 87, I'm getting about the same mpg's as 91, a little better lower end pickup at slower speeds and cheaper gas.
Emirates81
I DONT KNOW WHAT TO SAY
I had a 2008 JK which didn't seem to be powerfull and I got a tunner and tried with my friend Cherokee before and after tune , believe me there was a big big difference in power gain.
But this tunner I didn't get any any gain of power maybe maybe because its manual trans and it didn't work fine
So I am not happy at all
Here is the fix for the throttle issues on Manuals.
- trinity_dcx_gas-1t09hd_update.crom
- (2.96 MiB) Downloaded 239 times
