Freezing while monitoring
Re: Freezing while monitoring
I have a RIPP tune installed on the JK. Once we do the update will we have to flip the tune or can we just re-install the last tune?
restore, update, load a canned tune, reload custom tune to trinity, reload custom tune to truck.PRS wrote:I have a RIPP tune installed on the JK. Once we do the update will we have to flip the tune or can we just re-install the last tune?
1r11 is out, register/unmarried trintys will auto update.
dlayne2012
Has anyone tried the update yet? Any issues or new problems?
2007 Ram 1500
Trinity, HO Cams, Volant CAI/Custom Ram Air, Power Wire, JBA Shorty Headers, Magnaflow Y-Pipe, QTP E-Cutout, Magnaflow 14", Flexalite 183 E-Fan, 180 T-Stat, 08 Intake Manifold, F&B 72MM TB, SRT8 IAT Sensor, Mag-Hytech Covers, 4.56 LSD, ATI Super Damper 25%, BT Catch Can
tried it and now it wont save my stock tune, so not allowing me to do any tunes, very frustrating!!! and only had this for 6days now, guess I have to call in the am.
dlayne2012
I updated the tool to 1r11 and so far so good. I installed the diablo 93 tune and i just loaded my custom tunes to the trinity, so im off to load them on my truck. Hopefully all goes well.
2007 Ram 1500
what vehicle are you trying to tune? What is the error message you receive?fredmn25 wrote:tried it and now it wont save my stock tune, so not allowing me to do any tunes, very frustrating!!! and only had this for 6days now, guess I have to call in the am.
couldn't stand it and went ahead and put truck back to factory and downloaded the newest update.
same issues everyone else is having!
now it will not let me reload the original 1r10 download that I put back on the unit Monday.
says it's an old version and I need password from support tech to force it.
why did it not do this the other day when I went from 1r10g back to 1r10??
Same happening on my 2014 Ram 1500 5.7L.
Disappointing.
Disappointing.
we'll have this resolved shortly.
give this one a shot.
if it saves a backup for anyone, post the backup here please
- trinity_dcx_gas-1t11ad_update.crom
- (6.09 MiB) Downloaded 416 times
It didn't downgrade because 1r11 and 1r10 are different mega crom versions. You cant down grade to a version lower than the mega crom you are currrently on. Like for example i wanted to get back onto 1r09 while i was on 1r10. Well i found out the very thing you did. It is possible to downgrade but they don't like you to.snakebit wrote:couldn't stand it and went ahead and put truck back to factory and downloaded the newest update.
same issues everyone else is having!![]()
On another note. For the Techs, I also tested 1r11. I had no trouble saving my stock backup, loading my custom tunes, & tuning the truck. But it seems some settings in my trans custom tunes are not working. The shift points WOT and Part throttle are no longer what the CMR set them to. Even though i can not adjust them myself i tried it anyway on the second attempt with no luck. If its not one thing, its another.
Mikel, Not sure if it helps but here are my backups for my 06 RAM
- TCM_56029223AE.drg
- (147.68 KiB) Downloaded 441 times
- PCM_56029199AF.drg
- (63.33 KiB) Downloaded 333 times
2006 Ram 1500 quad cab 4.7L
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
72mm F&B Throttle body
DiabloSport Trinity
Gibson SS shorties
Edge 2800 Converter
tried again this morning and it worked.
did not update to the -ad- revision.!
going to play with it a little this evening.
is there any way to have the gauges read in F deg instead of C???
the ECT and In Man Air Temp are C.
yes, you can change them by selecting logging/create a new log, and click on the gauge and select change display units, then save and rename the layout.snakebit wrote:tried again this morning and it worked.
Working fine now....thanks!
