8 Speed Transmission
Re: 8 Speed Transmission
Lars, please give us a call and we'll swap that tool out for you, its missing a file needed to update properly.
Lars
Post by Lars »
Hi Mike,
thanks for this offer. I appreciate that. But I would like to mention that I come from Germany. It will be very complex and expensive to change the device.
If there is still any other idea to fix then we should try it before.
Lars
Lars wrote:I can do what I want. The device does no update.
Is there a possibility to reset the i2?
please try saving the attached file to the i2 drive and see if the device will import it.
nitrodave88
Post by nitrodave88 »
does anyone know if this helps the toqure converter shudder these 8 speeds have? or at least some of them have and mine is one lol
Lars
Post by Lars »
mikel wrote:please try saving the attached file to the i2 drive and see if the device will import it.
Unfortunately Not. :?
toneyjay
Post by toneyjay »
nitrodave88 wrote:does anyone know if this helps the toqure converter shudder these 8 speeds have? or at least some of them have and mine is one lol
Mine had the shudder and was replaced under warranty. That's the only repair. Other than dealerships doing a double flush to try and make it go away. :lol: I had to give a little fuss and they replaced mine.
nitrodave88
toneyjay did they do just converter or it and trans?
toneyjay
Post by toneyjay »
nitrodave88 wrote:toneyjay did they do just converter or it and trans?
Just the Converter
vig
Post by vig »
Just the Converter
any chance you're located in NJ? I'm looking for a lace that has done the TC replace before...
toneyjay
Post by toneyjay »
LOL not quite. SC.
Lars
Post by Lars »
Are there any other ideas besides the exchange of the device?
Lars
it will need to be swapped out, give us a call and we can get it set up.
nitrodave88
i sent in my tcm file and I haven't heard anything back and idea when might be a fix for these certain tcm
nitrodave88 wrote:i sent in my tcm file and I haven't heard anything back and idea when might be a fix for these certain tcm
when did you send in the file?
nitrodave88
I sent it over a week ago here it is again
TCM__UnknownBackup.grg
