Page 7 of 8
Posted: Mon Apr 06, 2009 8:44 am
by johan
Update to the latest Dataviewer, that issue was fixed there.
Posted: Mon Apr 06, 2009 10:01 am
by need-a-cage
I knew you were going to say that. I actually did upgrade to the latest but I didn't get a chance to try it out. I wanted to get the new t-stat in and I didn't want to get the truck hot so I just said hell with it and put in the t-stat.
I wanted to datalog the timing with the stock t-stat vs the 180 t-stat because someone on the Hemi Truck forum says that his timing with the 180 was lower. Here is a quote from him.
"I did some runs on the freeway with the 180 installed. Temp was a steady 184 deg. at 2000 rmp steady crusing the timing advance was 26 deg. I put the 203 factory back in, steady 201 deg. temp, the timing advance was 32.5 deg. at a steady 2000 rpm."
Is there anything in the tune that would cause this? Does the truck think it isn't warmed up all the way so it is holding back a little? I am thinking that if this is true then my mileage is going to get even worse!
Craig
Posted: Mon Apr 06, 2009 11:18 am
by johan
Interesting observation, there are adders and subtracters for ect but all the ones i see remove timing when it gets warmer.
u7137
Posted: Wed Apr 08, 2009 11:38 am
by Whoa
I have an 03 hemi and I haven't really noticed much of a difference since adding the 93 octane. How can I be sure that my tool is working properly? Is there a speed limiter for the 03?
RE: u7137
Posted: Fri Apr 10, 2009 10:48 pm
by crhemiram03
ya it stops you at about 104mph at least it does it for my 03. there workin on that, along with tranny. the only thing you can do with the 03's(well at least me) is tire size, wot fuel, wot spark. and of course the canned tunes
Posted: Fri Apr 17, 2009 9:47 pm
by lumpy69
Day 30 report
More Power -yes
Better Shifting -yes
Firmer Shifting -yes
Better Mileage - yes 10 tanks = +1 MPG Seems to have settled in. Avg city\hyw headwinds etc. etc.
Better Drivability -yes
Blips -cruise control kicks off @ 70MPH*****75MPH would be nice???
Happy Camper -yes
Thanks guys
Posted: Sun Apr 26, 2009 8:43 am
by Wolfman
lumpy69 wrote:Day 30 report
More Power -yes
Happy Camper -yes
Thanks guys
Right now I would say that I've seen some differences in the new beta crom..........I used the canned tune for 87 oct and it appears that the mileage has improved +1 or 2 mpg.........havent had the time to drive the 03 like I want to.....have a company car......so next time I make a trip in it will tell all............especially if I tow my enclosed trailer, full of tools and toys to my retirement property..........8 hrs away from here.......NOTE: Had some jerk turn left from the center lane in front of my wife and I last night as I was turning right.....put the pedal down and the 03 said hang on.......needless to say got away from being hit....I'll stick with the canned tune.......for now.
Posted: Wed Oct 07, 2009 10:48 pm
by lumpy69
anything new here?
Posted: Fri Oct 09, 2009 3:32 pm
by Harmwalker
Would be nice to get something new here. Been sitting with the same "Updateable Programmer" for about 6 months now...Like I always say, some downshift parameters would be nice for the '07's...
Posted: Fri Oct 09, 2009 8:43 pm
by white_lightning
I have been using 9t03c.
I like 9t03c, don't want to switch if the same feature aren't in the newer Croms.
any more shifting options being planned, 3-4 & 4-5 up, 5-4 & 4-3 down?
do Crom 9r04 & 9ro5 have the 1-2/2-3 tranny upshift & downshift programming that is in 9t03c?
observations about 9t03c:
part-throttle 1-2 & 2-3, 3-2 & 2-1 up-shifts/downshifts are a neat feature, but some shifts don't seem to get set @ the rpm selected.
example: I set 1-2 up @ 5% TPS for 2,000 rpm & it got written to 1,850 rpm, 2-1 down @ 10% TPS for 1,800 which set @ 1,750 rpm.
I have found that set up/down shifts need to be set further apart since shifts don't get set at the selected rpm.
1-2 & 2-3 WOT shifts have been right on every time, set them for 6,200 rpm & they get written at 6,200 rpm.
being able to raise 3-4 & 4-5 WOT shifts would be nice, can it be done?
Posted: Sat Oct 17, 2009 5:29 pm
by Charger250
How is the beta comming?
Posted: Thu Nov 19, 2009 12:56 am
by ROADRAMBLERNJ
bump
Posted: Thu Nov 19, 2009 1:00 am
by lumpy69
any replies here,curious minds would like to know
Posted: Tue Dec 15, 2009 9:12 pm
by lumpy69
hello
Posted: Tue Dec 15, 2009 9:25 pm
by xsignature
lumpy69 wrote:hello
this thread is old and that beta already has been replaced. it was the 9t03 and became the 9r03 and they are up to 9r04 i think if not newer.
