New U7194 update, new tunes!
coltabilly
Post by coltabilly »
I'm a little lost. Should I use crom 21a, b, or c?
2003 Silverado
2005 Corvette Coupe
2010 Camaro SS
gundog
unable to update from 9r18
Post by gundog »
When I attempt to update from v. 9r18 to either 9r21 or 9r21c my 7194 advises that it is unable to downgrade from 9r16. I'm confused....now what?
HMCDano
Re: unable to update from 9r18
Post by HMCDano »
gundog wrote:When I attempt to update from v. 9r18 to either 9r20 or 9r20c my 7194 advises that it is unable to downgrade from 9r16. I'm confused....now what?
I get the same thing......I have tried 9r21 and 9t21c and I get the same error.
HMCDano
RE: Re: unable to update from 9r18
Post by HMCDano »
I got the 9t21c to work. I had to download and install the 9r19 crom first.
You can get the 9r19 crom in the message below
http://diablosport.com/index.php?name=P ... 359#164359
2010 Camaro SS/RS L99
Custom Magnaflow Catback
Diablosport Tune
gundog
Post by gundog »
Thanks, now updated to 9r21... Now the question, for a 2007 Yukon with the 5.3 flex, was the upgrade of benefit or did I just use up more memory to install the update since it is larger in size? If nothing gained what revision would give me the latest improvement in my Yukon without using excessive memory that may be better utilized for logging purposes.
Thanks again
Bubbatex0
Update
Post by Bubbatex0 »
Would it do any good to try to update from 9r13 to 9r21 on a 2008 5.3 Sivarado? Bought my Predator in May of 08. Will the 9r21 fit in it?
Thanks,
Robert
IOMSS
RE: Re: New Tunes
Post by IOMSS »
I have a 2010 Camaro SS L99. It sounds like I should update. I haven't been on here for a while and thought I would see if I was missing anything. Dose the Predator now have tranny tune? Will the update help me? I'm running a Vararam intake and Magna Flow comp cat back.
VR CAI, Magna Flow comp cat back, RX catch can, CFD pistal grip tap shifter
IOMSS
RE: Re: New Tunes
Post by IOMSS »
sorry, missed a couple of pages on the thred. Guess I'll try an update! Mine is still running 9r15. Can I go right to 21b or do I need to do a bunch of updates??
Re: RE: Re: New Tunes
IOMSS wrote:sorry, missed a couple of pages on the thred. Guess I'll try an update! Mine is still running 9r15. Can I go right to 21b or do I need to do a bunch of updates??
you need to search the forum and update to 9r19 first... then you can go to the newest one after that...
Re: Update
Bubbatex0 wrote:Would it do any good to try to update from 9r13 to 9r21 on a 2008 5.3 Sivarado? Bought my Predator in May of 08. Will the 9r21 fit in it?
Thanks,
Robert
yes... go to revision 9r19 first, as mentioned above...
IOMSS
Post by IOMSS »
Hey Lew, I tried to update today. Updater will not work!! it freezes on the "please power cycle tool" window. The driver is installed and working but it only takes over the tool when Dataviewer is open. Downdoader does list the port and baud rate so It is recognizing the location ok. Help!!!!! The tool is about 1 year old!!!
RE: Re: RE: Re: New Tunes
are you using the newest version of the DSDownloader??
IOMSS
Re: RE: Re: RE: Re: New Tunes
Post by IOMSS »
06MonteSS wrote:are you using the newest version of the DSDownloader??
Yup, just downloaded it!!! Again
RE: Re: RE: Re: RE: Re: New Tunes
have you ever updated the tool before, or exported tune files from it using the dsdownloader??
wondering if the dsdownloader is really seeing/finding your tool...
com port is set to 1, 2, 3, 4, or 5... and the baud rate is 57600 or 115200?? in both the dsdownloader AND in your settings/properties for the usb cable in windows device manager??
IOMSS
Re: RE: Re: RE: Re: RE: Re: New Tunes
Post by IOMSS »
06MonteSS wrote:have you ever updated the tool before, or exported tune files from it using the dsdownloader??
No, haven't updated before. I messed with it and got it working. Thanks!!!!!
The com port was showing"com 3" I changed it to "com 4" and it worked fine.
