awesome, glad to hear it, enjoy!Ufoldfirst wrote:'13 300S 5.7
installed 1t10ba, loaded 91oct tune - 92oct is highest out here....
immediately this car idled smoother, ran smoother through rpms.
alot more power, makes up a little for the taller gear - going from charger r/t daytona to a 300 seemed like driving a school bus!
thanks again DS and team for the support!
Successful 2013 installs please chime in!
Re: Successful 2013 installs please chime in!
DarkKn1ght
I just drove her home from work. I'm going to put her on a trickle charger and try again.mikel wrote:No, so far anyone with this issue has been able to get around it with a few more tries, especially after driving around for a bit to ensure good battery charge.DarkKn1ght wrote:That's the same file Mike M. emailed me last week. Should I try the older cc update that I saw posted on the forums?
2013 Dodge Charger SXT+ Blacktop Edition
Mid-Atlantic Modern Mopars
DarkKn1ght
I tried again and again. When it finally saved the backup file, it almost finished the tune file when it caused the car to change from run to off. It said something about a boot logger fail. Afterwards it gave me the option to restore the original file. I told it no and it crashed. I tried hitting no again and it crashed again. I installed the original file and then it gives me the option to tune again but I have to save the original file again. I tried to save the original file and it failed over and over. Needless to say I'm not happy. I just want to tune the car. Please shed some light on this besides saying try to backup the file again.
OK, please post your VIN and calid (options/troubleshooting) and hold off for now so we can look into this.DarkKn1ght wrote:I tried again and again. When it finally saved the backup file, it almost finished the tune file when it caused the car to change from run to off. It said something about a boot logger fail. Afterwards it gave me the option to restore the original file. I told it no and it crashed. I tried hitting no again and it crashed again. I installed the original file and then it gives me the option to tune again but I have to save the original file again. I tried to save the original file and it failed over and over. Needless to say I'm not happy. I just want to tune the car. Please shed some light on this besides saying try to backup the file again.
wait, if it turned the car off on its own, you may have timed out of run mode....was the door closed?DarkKn1ght wrote:I tried again and again. When it finally saved the backup file, it almost finished the tune file when it caused the car to change from run to off. It said something about a boot logger fail. Afterwards it gave me the option to restore the original file. I told it no and it crashed. I tried hitting no again and it crashed again. I installed the original file and then it gives me the option to tune again but I have to save the original file again. I tried to save the original file and it failed over and over. Needless to say I'm not happy. I just want to tune the car. Please shed some light on this besides saying try to backup the file again.
had you been inthe car for 20+ minutes?
Sometimes you want to keep the door open to keep the key from timing out on you in the middle of the process.
DarkKn1ght
mikel wrote:OK, please post your VIN and calid (options/troubleshooting) and hold off for now so we can look into this.DarkKn1ght wrote:I tried again and again. When it finally saved the backup file, it almost finished the tune file when it caused the car to change from run to off. It said something about a boot logger fail. Afterwards it gave me the option to restore the original file. I told it no and it crashed. I tried hitting no again and it crashed again. I installed the original file and then it gives me the option to tune again but I have to save the original file again. I tried to save the original file and it failed over and over. Needless to say I'm not happy. I just want to tune the car. Please shed some light on this besides saying try to backup the file again.
CalID: 68171344AD
VIN: 2C3CDXHG4DH546396
DarkKn1ght
I had it on the trickle charger with the light switches on the lowest setting, the doors closed, radio screen off, auto headlights off, and the radio off. I also had the keys in the little cubby hole in front of the shifter.mikel wrote:wait, if it turned the car off on its own, you may have timed out of run mode....was the door closed?DarkKn1ght wrote:I tried again and again. When it finally saved the backup file, it almost finished the tune file when it caused the car to change from run to off. It said something about a boot logger fail. Afterwards it gave me the option to restore the original file. I told it no and it crashed. I tried hitting no again and it crashed again. I installed the original file and then it gives me the option to tune again but I have to save the original file again. I tried to save the original file and it failed over and over. Needless to say I'm not happy. I just want to tune the car. Please shed some light on this besides saying try to backup the file again.
DarkKn1ght
This morning I turned on the car and the check engine light was on. The Trinity found no codes but was able to clear the light.
Same here.. what i didi i disconnect the battery and reconnect.. now its ok.DarkKn1ght wrote:This morning I turned on the car and the check engine light was on. The Trinity found no codes but was able to clear the light.
But why the check engin light with no code!
DarkKn1ght
So I'm assuming you want me to try again with the door open this time? Is there anyway you guys can come up with a release for the 2013's that doesn't require it to fail 24/25 times?
thats not the plan at all. We are looking into it.DarkKn1ght wrote:So I'm assuming you want me to try again with the door open this time? Is there anyway you guys can come up with a release for the 2013's that doesn't require it to fail 24/25 times?
13killerbee
DarkKn1ght wrote:I had it on the trickle charger with the light switches on the lowest setting, the doors closed, radio screen off, auto headlights off, and the radio off. I also had the keys in the little cubby hole in front of the shifter.mikel wrote:wait, if it turned the car off on its own, you may have timed out of run mode....was the door closed?DarkKn1ght wrote:I tried again and again. When it finally saved the backup file, it almost finished the tune file when it caused the car to change from run to off. It said something about a boot logger fail. Afterwards it gave me the option to restore the original file. I told it no and it crashed. I tried hitting no again and it crashed again. I installed the original file and then it gives me the option to tune again but I have to save the original file again. I tried to save the original file and it failed over and over. Needless to say I'm not happy. I just want to tune the car. Please shed some light on this besides saying try to backup the file again.
Hello DarkKn1ght, I am just wondering have you downloaded the trinity-1r10.crom first and then the trinity_dcx_gas-1t10ce_update.crom after? If you are getting an error for a bootleg file it could mean you haven't installed the "core" .crom(trinity-1r10.crom). If you update to 1r10 first and after that finishes, update to 1t10ce it should fix the error of of a missing bootlegger.
DarkKn1ght
I installed the base one followed by the 1b dcx one followed the the 1ce dcx one. Should I start over and install the base one followed by the 1ce dcx one?
13killerbee
Yes, try installing the base followed by the 1ce.DarkKn1ght wrote:I installed the base one followed by the 1b dcx one followed the the 1ce dcx one. Should I start over and install the base one followed by the 1ce dcx one?
DarkKn1ght
My bootloader is still showing version 0.0.
