Page 7 of 11
Re: 2015 F150
Posted: Fri Jul 17, 2015 3:26 pm
by kellyfj10
sohfast94 wrote:
kellyfj10 wrote:
sohfast94 wrote:We found one locally that exhibits this. I'm getting it in here tomorrow and we'll see what we find.
Were you able to find out anything with the local tester?
Throttle does not die on the local one. Did have surging which was fixed in the latest tester that has been posted here previously.
If I load the latest tune, the gg, what do I do so you can see what is happening. will help anyway I can.
Re: 2015 F150
Posted: Fri Jul 17, 2015 3:34 pm
by sohfast94
Might as well make sure you're completely up to date.
Re: 2015 F150
Posted: Fri Jul 17, 2015 4:59 pm
by juangorena
sohfast94 wrote:Might as well make sure you're completely up to date.
i´m going to install it , as son as i get a clue of how its working i will let you know , regards
Re: 2015 F150
Posted: Sat Jul 18, 2015 11:35 am
by juangorena
The truck is doing a lot of spitting and sputtering i used 93 performance, also you can hear like small explosion in the exhaust,
turbo kpa goes up and dow up and down at WOT ,
fuel consumption increased in a 40%
have you seen my previous logs ?? does this logs helps in any way ?
Re: 2015 F150
Posted: Mon Jul 20, 2015 8:57 am
by kellyfj10
Loaded the tune in Friday, drove the truck on Saturday and Sunday, this morning lost all throttle in the middle of an intersection. I did not have my tuner hooked up so I did not get a log of it.
Re: 2015 F150
Posted: Mon Jul 20, 2015 9:25 am
by sohfast94
juangorena wrote:The truck is doing a lot of spitting and sputtering i used 93 performance, also you can hear like small explosion in the exhaust,
Please read out the last tune written and post it. Also check plug gap as the logs look good and the truck is doing what it should be.
Re: 2015 F150
Posted: Mon Jul 20, 2015 12:42 pm
by juangorena
I removed the tune from the truck since it didn´t behave correctly it increased the fuel consumption in a 40% also on the exhaust i found
Heavy carbon deposits , during the test check engine lamp pop up at intermitent cycles , today i´m going to try the 91 performance tune
Re: 2015 F150
Posted: Tue Jul 21, 2015 9:46 am
by sohfast94
I would check plug gap
Re: 2015 F150
Posted: Tue Jul 21, 2015 8:47 pm
by Roiceed
After 70 miles I lost all throttle response. So I guess back to the drawing board again.
Re: 2015 F150
Posted: Wed Jul 22, 2015 3:28 pm
by juangorena
truck is only 4000 miles , should i suspect for a damaged spark plug or inadecuate gap cal ?
i tried the las tune with the 91 performance it seemed to work better but i los all throttle at a 30 miles of driving it , there is still a big issue there , the problem here is that you lost compeltely acceleration in the middle of the traffic :?
Re: 2015 F150
Posted: Thu Jul 23, 2015 11:54 am
by Roiceed
sohfast94 wrote:I would check plug gap
Check the plug gap? I would think by now you'd understand that the issue is on your end, not ours. :punisher:
Re: 2015 F150
Posted: Mon Jul 27, 2015 1:54 pm
by sohfast94
Emailed.
Re: 2015 F150
Posted: Mon Jul 27, 2015 4:06 pm
by kellyfj10
Emailed.
Is there any fix for the throttle issue yet? not trying to pressure you, just excited to get it installed.
Re: 2015 F150
Posted: Mon Jul 27, 2015 4:11 pm
by sohfast94
Emailed.
Re: 2015 F150
Posted: Tue Jul 28, 2015 10:25 am
by juangorena
sohfast94 wrote:
Emailed.
Email it to me too ! [email protected]
