LS1/LS2/LS3/LS4/LS7 etc. - LOGGING, ADJUSTING INJECTOR SLOPE
jsk06c6
Post by jsk06c6 »
take -5 out on your slope and do another run after 30-50 miles.
BTW, you had the perfect settings to get your ltft's, throttle and rpm.
bdiwha
Post by bdiwha »
Do all my numbers look alright though? I don't have anything crazy? I think I will adjust, and on the next log I will list all the sensor data, cause I have a few more readings when in 'diagnostic' that I believe are all electrical current readings for the o2s.
thanks
-dave
'05 silverado 1500 z-71. k&n, 3" flowmaster with single out(retaining factory exit position), mobile 1, and my good looks...
jsk06c6
Post by jsk06c6 »
bdiwha wrote:Do all my numbers look alright though? I don't have anything crazy? I think I will adjust, and on the next log I will list all the sensor data, cause I have a few more readings when in 'diagnostic' that I believe are all electrical current readings for the o2s.
thanks
-dave
Nothing that stikes me as being odd. I really don't look at some of the data you have listed though.
CANUCKPREDATOR
logging under load
Post by CANUCKPREDATOR »
I have 07 GMC Sierra 5.3l (NBS) and U7194 programmer. Just reading through and getting ready to do some logging and fine tuning and I had a thought. I pull a trailer quite a bit (travel trailer or ATV trailer loaded), would it make for more accurate settings for my out fit if I log under the conditions that it will be under most of the time. I'm thinking about logging with a trailer in tow and then make adjustments from there.
Is this logical or is my thought process flawed?
sickREDsierra
RE: logging under load
Post by sickREDsierra »
unless you tow your trailer 24/7... i would log my real time data without it attached, and get my fueling/spark where it needs to be. that will improve your towing performance alone.
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
CANUCKPREDATOR
would it make sense then to do a log and adjustments for towing and save it and install it when I am towing? and have a tune for when I'm running empty?
yeah, you can do that... but it'll be a lot of back and forth with exporting/importing tunes to/from the predator/PC...
CANUCKPREDATOR
I'm gonna do some experimenting and if it is worth the time and effort to import/export a "towing tune" that has better performance and/or mileage, then I'll do it. I'll keep you guys posted on my results.
bdiwha
Post by bdiwha »
I seem to have my truck tuned fairly well, but every now and then it will give me a bit of spark knock and less power under WOT. I would like to run a log and see what it is at under WOT, but what are my optimum numbers going to be? What are my targets?
bdiwha
Post by bdiwha »
Oh, I had already posted my last readings in here, should be back on page six.
-Dave
Torrid
Post by Torrid »
Is the PE the WOT fuel? If that's the case, I was told to pull both from injector slope and this at the same time, then I'll zero out my lean/rich setting and leave my -8% setting I changed to and achieved -.78. I haven't taken it full throttle since the changes, but I'm starting to think this may be the reason why I'm getting light KR with more aggressive throttle since I changed both instead of just injector slope.
yes, PE (Power Enrichment) is the WOT fueling...
Torrid, you could be getting the KR at WOT because you took out too much fuel in the PE settings and are now too lean...
I get my slope adjusted to get my ltft's at -1, and then leave my PE settings alone at the default 0 settings... and this gives me an AFR at WOT of 12.6 to 12.8....
Torrid
Post by Torrid »
I think that did the trick. It almost scared me how hard it pulled with the proper settings, the tires ripped loose so fast I thought I was going to lose control of it on the rolling start. The car really came alive. I'd still like to check my AFR, but I'd say I'm probably in that range based on the huge difference in power I've felt.
;) nice!!! glad to hear it man!!
bdiwha
Post by bdiwha »
06MonteSS, what if my tuner does not display an actual AFR in the Diagnostic mode? What can I look at to calculate this, or is there something else I could monitor under WOT other than just cruising and looking for LTFTs?
-Dave
