Hello ,
( first of all I am French so I apologize for the translations can be a bit random )
I loaded the 93 octane melody with some additional settings .
I charge at 1.4 bar ( 21 psi ) in full gas ... the problem is that if I put a full gas at 2500rpm I also take 21 psi but the boost solenoid setting does not work!!!
How can we solve this problem?
thanks
problem adjusting turbo pressure
Re: problem adjusting turbo pressure
SRT4?
the tune we provide already adds max WG pressure, there is no more to add once the tune is loaded.
french srt4
Thank you for your answer ,
yes srt4.
everything has done but I would like to reduce it on the regime of 1500 to 3500 tr
it's possible ?
yes srt4.
it's possible ?
yes you can pull it back a bit if needed.
