01 v6 stang axle ratio
v6procharged
i have a tuner series predator. p/n U7000. i drive a 2001 3.8 v6 mustang and i just installed a new rearend with 3.55s in it and the tuner is not correcting the speedo. its collecting more miles than it should be. plz help asap.
RE: 01 v6 stang axle ratio
Can you send me your last tune written and I'll take a look at it.
Insert Clever comment here...
v6procharged
i will try to today when i get off work. how exactly do i send it to you? i dont get off until 5:30 so i might be able to call if i have trouble.
You use DSDL and then tell it to get tune file from predator. It will give you an option to select yes or no select no.
v6procharged
ok, once the file is on my computer, how do i send it to you?
Just click the email tab and send it to me.
v6procharged
ok, how long will this take for you to be able to modify this tune if you can?
20 minutes or so.
v6procharged
ok, yall close at 5 though dont you?
- Vas@Diablosport
v6procharged
ok. i get off at that time, so i can just send the tune to email and get it back tommorow or something. thanks for yalls help.
v6procharged
is there anything you can do about how it takes off? it kinda bogs down. and the idle is really rough sumtimes, like i have a serious cam.
Toon Sent.
v6procharged
alright thanks. it is tuned for the 11lbs correct? will it be ok to get on it with the 9lb pulley to datalog it or should i wait til i install the 11lb pulley?
Doesn't really matter. Either way.
