All 3 Torque Management Parameters OFF by default? U7193
SummitUp
Post by SummitUp »
U7193 software revision v. 2.10 - 2005 Hummer H2
Performance 93 Octane tune:
When I go to "Modify Tune" > "Torque Management," all 3 parameters are "OFF" by default, or at least "OFF" is highlighted. Does this option actually reflect the status of T/M? And if so, why would the Performance Tune turn all 3 T/M options to "OFF"?
Since it is advised that the 3rd parameter "Upshift Torque Reduction" be left ON for trucks and large SUV's, I highlight "ON" for "Upshift Torque Reduction," and answer yes to "do you want to save changes," and re-install the modified tune.
But when I re-enter "Modify Tune" and go back to "Torque Management," "Upshift Torque Reduction" is still set at "OFF." Why can't I turn it on as is advised?
CANUCKPREDATOR
RE: All 3 Torque Management Parameters OFF by default? U7193
Post by CANUCKPREDATOR »
That is not indicating that it is turned off, that is asking do you want it turned off.
From what I've read you want the first two OFF and the third one turned ON
OMENOUS
Post by OMENOUS »
must be nice...
06 Trailblazer SS
05 GTO
98 Corvette
johan
Post by johan »
Those parameters with switches default to the top menu item in that selection, it does what you change it to but once you go back it will default to the top menu item.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
SummitUp
Re: RE: All 3 Torque Management Parameters OFF by default? U
Post by SummitUp »
johan wrote:Those parameters with switches default to the top menu item in that selection, it does what you change it to but once you go back it will default to the top menu item.
johan, thanks for the info! That's the information I was looking for, and I was thinking that this was probably the case.
So based on this information I shouldn't assume that the first two parameters are really "OFF," even though "OFF" is highlighted when you go into the T/M menu selection (because it defaults to the top menu item which is "OFF").
I'll go back and select "OFF" for the first 2 T/M parameters and then save the settings to make sure they really are "OFF."
It sure would be nice if there was some way to really know for sure that T/M was really disabled ("OFF").
